hmi io6 module replace
Old Dec 30, 2020 | 07:30 AM
nitroz19's Avatar
nitroz19
Default hmi io6 module replace
How hard is it to remove the HMI module on a 2019 Grand sport, and What are the steps to do so?
Old Dec 30, 2020 | 08:34 AM
JMII's Avatar
JMII
Easy to remove... more information and a video here: https://www.infotainment.com/product...nt=42428691143
Take note that a new or used module will have to be programmed to your VIN.
Old Dec 30, 2020 | 08:58 AM
nitroz19's Avatar
nitroz19
thanks I saw that, but they did not really show/explain the steps involved.
I have been told there are two latches on both sides of the module,I can't see them.
Also would kind of like to know if you can unlatch them by hand or does it take a tool
Old Dec 30, 2020 | 11:32 AM
JMII's Avatar
JMII
I never actually removed mine but if its like the similar radio module in the passenger side footwell / firewall it just unsnaps. The unit sides into a plastic tray that has tabs or clips that keep it snug in there. No tools required. I would just feel around up there and/or use your phone to shoot a quick video that you can review outside the car to help you locate the tabs. I suggest you wear gloves as the surrounding plastic and metal is unfinished and thus tends to have sharp edges which can cut you.
Old Dec 30, 2020 | 12:26 PM
nitroz19's Avatar
nitroz19
thanks I will try that
To hmi io6 module replace
