Why is my coolant temp 260f!
Old Mar 20, 2021 | 11:39 AM
123sugey's Avatar
123sugey
Dig
Originally Posted by jimxms
I wasn't driving hard-hard, as my car is still in the process of being tuned for the additional boost. However I did a couple of pulls to about 5k rpm and a bit of driving around town. So no where near the level of hard use it would see on a track.
Not the stock cooling system. As mentioned in my first post I'm running a performance radiator (about 2x thicker core than OEM) and also mostly straight water + water wetter. I also have a 160deg Tstat and have deleted my A/C so thats one less radiator for air to pass through.
There's no harm in removing the tstat just for testing purposes is there?
I may put a thermal probe on the intercooler too to see how much heat that is adding. Its hard to get a good idea based on AIT's as I'm spraying meth.
Cant hurt to try removing the stat and see how it goes
Old Mar 20, 2021 | 11:54 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Remove the thermostat and put it in a pot of water. Monitor temp as the pot heats up and see if it opens around 180-190 F (80-90C). If it never opens and the water is boiling you have an issue.
Old Mar 20, 2021 | 02:41 PM
asc709's Avatar
asc709
I’m looking at the oil pressure reading....that normal for a LT1?
Old Mar 20, 2021 | 07:06 PM
fatsport's Avatar
fatsport
Did you ‘burp’ your cooling system? Air getting stuck will easily do this.
Old Mar 20, 2021 | 09:31 PM
BooSSted's Avatar
BooSSted
I had a similar issue with tstat and aftermarket housing.. I ditched them both back for OEM, well actually a katech tstat and the car is running/operating cool again. In my experience the housing wasn't allowing the tstat to fully open. Billet housing, from a very reputable company. Plastic OEM unit worked like a charm.
