I would really start with a set of aftermarket wires. I run the 12" extra length Speed Engineering as they give you a little extra to be able to move the wire around a little to make sure they don't touch the header tubes. Sometimes its very hard to get the wire end on the plug properly, it takes a little moving it around to make sure it actually clicks on the plug end. You can look very easily at the coil connection to see if they all look equal but its hard to see that on the end of the plug. We've probably all had this problem when putting the old plug wires back on or event the new one. Its also possible when you were installing one of the new plugs you may have cracked the one of the plugs with the socket tightening them down. Hope you get it figured out.
Don’t give up. It took me 3 months to fix the misfire after my header install. The results are worth it. In my case the plugs were cracked, but you couldn’t really tell by looking at them. If you’ve done all the ignition cures then I’d replace the exhaust gaskets.
