Shudder at different Speeds
Old Jul 9, 2021 | 10:42 AM
ILOW93's Avatar
ILOW93
6th Gear
Default Shudder at different Speeds
New to the corvette would. Not starting out too good, but hopefully this form can change that for me. I have a 2017 C7 stingray , I get a stutter while driving it happens a different speeds. Its like a little jerk ,
The dealership clams they can not duplicate the issue
Old Jul 9, 2021 | 10:58 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome, you probably need the trans triple flushed...moved you here to meet the right folks.. Intros, just for that .. Introductions..
Old Jul 9, 2021 | 12:17 PM
ILOW93's Avatar
ILOW93
6th Gear
the car only has 33,000 miles would the trans need flushing that soon?
Old Jul 9, 2021 | 01:29 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Well, there is a bad engineering issue in the A8. It seems that the transmission fluid soaks up moisture from the air. It gets to the point when driving along at 70 MPH and you will get a shudder as the car switches from A8 to A4. You can see the RPM snap when it happens. If you put the car in "M" and manually shift and drive, if the fluid is the problem, the shudder will stop as the A8/A4 process is stopped when in "M".
There is a unit called the "Range" device that will plug into the DTC port under the dash and keep the car in A8. This will usually stop the issue but obviously not correct the issue.
There is a TSB that requires the flush to fix the issue. GM found the fluid problem and corrected it in March of 2019.
You have not really defined the problem to us but that's my guess.
Elmer
Old Jul 9, 2021 | 02:06 PM
ILOW93's Avatar
ILOW93
6th Gear
Where can I purchase the "Range" unit?
Old Jul 9, 2021 | 03:07 PM
eboggs_jkvl
Moderator emeritus
https://www.rangetechnology.com/prod...-dfm_disabler/
YOu might still be in warranty to get the TSB done for free.
Elmer
Old Jul 9, 2021 | 03:46 PM
seniorstorekeeper's Avatar
seniorstorekeeper
Earlier posts are all correct. Get the triple flush done under power train warranty and then install the Range Device from Range Technologies. Probably just a shudder going from V8 to V4 mode because of all GM vehicles having AFM, which is for fuel savings. It is a pain on all GM vehicles with AFM, but easily corrected.
Old Jul 9, 2021 | 09:57 PM
AZRenegade's Avatar
AZRenegade
If you order a Range unit, order directly from their site. That ensures that you will get the most current version. I was informed by Range support just today that the unit I ordered a few weeks ago was manufactured in June and has version 9.
Old Jul 10, 2021 | 12:24 PM
ILOW93's Avatar
ILOW93
6th Gear
Thanks that's what I did.
Old Jul 10, 2021 | 12:34 PM
AZRenegade's Avatar
AZRenegade
Here is some informative reading on the shudder issue. It may help you decide whether or not to purchase a Range unit:
The real reason why Corvette C7 Stingray uses steel torque tube and why this signifies the fundamental failure of the new car | corvette c7 stingray and Z06 exposed (wordpress.com)
Gears Magazine | What is Causing that? A Look at the GM 8L90's Most Common Concerns
Old Jul 12, 2021 | 10:11 AM
SouthernSon's Avatar
SouthernSon
Before you have it flushed you might call the parts department and verify they have the latest, greatest fluid in stock. Then talk to the service manager and ask how they flush it (research it - lots of info on the forum). If all seems in order then expect it to take 3 hours or so and cost somewhere around $700. At least that is the cost for a C7 ZR1. BTW, mine doesn't jerk but used to 'shudder' after fluid warmed up and at steady cruise. It has no cylinder deactivation. Different models of C7 manifest the problem somewhat differently but most are all related to old generation of tranny fluid.
Old Jul 13, 2021 | 09:57 AM
Elk's Avatar
Elk
While you are receiving excellent advice regarding the transmission shudder, and it is worth getting the flush if your car is still under the power train warranty, you may not have the shudder.
The shudder is described as akin to driving over rumble strips. Are you experiencing this?
You described the problem, "Its like a little jerk." Can you elaborate on this? Perhaps you have an issue unrelated to the shudder.
Old Jul 13, 2021 | 10:04 AM
seniorstorekeeper
Very interesting article's from AZRenegade, especially the one about the torque tube and AFM. Just another reason that AFM is not a good thing to have on any vehicle car or truck.
To Shudder at different Speeds
