Remote start
Old Apr 30, 2021 | 07:44 PM
Rwp315's Avatar
Rwp315
Default Remote start
Replaced the battery in my ‘15 c7. First rejected Illinois emissions test. So have to wait 6-7 days for retest.
Second, remote start doesn’t function.
Any suggestions?
RWP
Old Apr 30, 2021 | 07:52 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Press "Lock", then start it? It won't do it two times in a row without the car actually being started.
Elmer
Last edited by eboggs_jkvl; May 1, 2021 at 11:57 AM. Reason: Edited to correct unlock to lock. Old guy, cut me some slack!
Old Apr 30, 2021 | 08:07 PM
pit-man's Avatar
pit-man
Originally Posted by eboggs_jkvl
Press "Unlock", then start it? It won't do it two times in a row without the car actually being started.
Elmer
i thought it was lock, then remote button
Old Apr 30, 2021 | 08:20 PM
Rwp315's Avatar
Rwp315
Elmer
I’ll try tomorrow.
Thanks,
RWP
Old Apr 30, 2021 | 09:52 PM
RonC7's Avatar
RonC7
Yeah, you need enough ignition cycles for the emissions sensors to show "ready" when scanned. The indication clears with power interruption. Just drive the car for a week or two if you don't have a code scanner.
Press Lock and hold remote start on the fob for 4 sec per the manual.
Ron
Old Apr 30, 2021 | 11:21 PM
Rwp315's Avatar
Rwp315
Thanks,
RWP
Old May 1, 2021 | 08:43 AM
eboggs_jkvl
Moderator emeritus
Well, hell, it was one of those damn buttons! It probably was lock. My bad!
Remote Vehicle Start
If equipped, this feature allows the
engine to be started from outside
the vehicle.
Starting the Vehicle
1. Press and release "LOCK" on the
RKE transmitter.
2. Immediately after completing
Step 1, press and hold "Start" for at
least four seconds or until the
turn signal lamps flash.
3. Press the brake pedal and select
the ON/RUN/START
ignition mode.
When the engine starts, the parking
lamps will turn on and remain on as
long as the engine is running. The
doors will be locked and the climate
control system may come on.
The engine will continue to run for
10 minutes. Repeat the steps for a
10 minute time extension. Remote
start can be extended only once.
Canceling a Remote Start
To cancel a remote start, do one of
the following:
. Press and hold "Start" until the
parking lamps turn off.
. Turn on the hazard warning
flashers.
. Turn the vehicle on and then off.
Elmer
Old May 1, 2021 | 11:37 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
It's lock
Old May 1, 2021 | 01:10 PM
Rwp315's Avatar
Rwp315
Great, thanks.
I’ll go through the procedure today.
To Remote start
