Slight backfire at shift
Old May 1, 2021 | 05:08 PM
ohmygod's Avatar
ohmygod
Default Slight backfire at shift
Not that I do it very often, but taking of in rapid exceleration I got a very slight backfire at shift from 1st to 2nd and again from 2nd to 3rd. It was minor but noticeable. Thought on the cause and remedy? Never done it before and the car has 7500 miles (2017 GS)
Old May 1, 2021 | 06:35 PM
laserdude2215's Avatar
laserdude2215
Perfectly normal! Do a search for "backfire".
Old May 1, 2021 | 07:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
AAAAHHH...NOOOO !!...backfires are NOT normal !!
Old May 1, 2021 | 07:43 PM
C5 Diag's Avatar
C5 Diag
Does it sound like it’s coming from the intake or exhaust ??...best thing is to put a scan tool on the car to see what DTC’s you may have and the first data PID I would look at are your fuel trims just to get some direction.
Old May 1, 2021 | 07:57 PM
laserdude2215
People like to call it a backfire, but it's really an exhaust pop caused by the fuel cut during the shift. And, it is normal. Better?
Old May 1, 2021 | 08:09 PM
laserdude2215
Waste of time.
Old May 1, 2021 | 08:12 PM
C5 Diag's Avatar
C5 Diag
The “D” in DFCO is decell...OP says it happens during ACCELERATION !!...better ??
Old May 1, 2021 | 08:19 PM
laserdude2215
Not better! The pop is an ACCELERATION event. DFCO is something entirely different.
Old May 1, 2021 | 08:27 PM
C5 Diag's Avatar
C5 Diag
Never heard of an acell POP !!...it’s decell fuel cut off...you’re telling me this is an acell fuel cut as you call it then ??...post this article !!...do what’s causing this “pop “ then ??
Old May 1, 2021 | 08:37 PM
FlBoy's Avatar
FlBoy
When I had that on my Porsche Carrera it turned out to be a bent valve....
Old May 1, 2021 | 08:42 PM
Dcasole's Avatar
Dcasole
OMG dude back off LaserDude is 100% correct , it is normal ....
Dave
Old May 1, 2021 | 08:45 PM
Dcasole's Avatar
Dcasole
OP , Its perfectly normal and still brings a smile to my face everytime I hear it ....
Dave
Old May 1, 2021 | 08:49 PM
C5 Diag's Avatar
C5 Diag
Dave
Is this in a TSB or in SI perhaps ??...just curious !!
Old May 1, 2021 | 09:09 PM
Dcasole's Avatar
Dcasole
Why would there be a TSB OR SI for something that is perfectly normal on a A8 , for a split millisecond fuel and spark is cut during a WOT upshift on the 1st to 2nd and then again on the 2nd to 3rd upshift . Corvettes are not the only cars that do this
Dave
Old May 1, 2021 | 09:37 PM
C5 Diag's Avatar
C5 Diag
Dave
Thanks !!...I’ll look into this !!
Old May 2, 2021 | 01:29 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
I dont want to get in the middle of a fight but mine does it too. (16 Z51 A8 ) Reminds me of the old days when you'd get a pop when you
made a good power shift in a 4 spd muscle car.
Old May 2, 2021 | 04:28 PM
Dcasole's Avatar
Dcasole
Originally Posted by 0311 jarhead
i dont want to get in the middle of a fight but mine does it too. (16 z51 a8 ) reminds me of the old days when you'd get a pop when you
yep 👍👍👍👍
To Slight backfire at shift
Old May 2, 2021 | 05:07 PM
Goshawk23's Avatar
Goshawk23
Mine does it as well on upshifts.
Old May 2, 2021 | 05:22 PM
Sloblk8's Avatar
Sloblk8
Yep, mine does it too. I actually hate that it's not more pronounced and man it sounds so good when it does it under overpasses!
Old May 3, 2021 | 01:59 PM
davanz's Avatar
davanz
One clarification. To cut/unload the torque on the transmission clutches and gears during hard acceleration, the ignition is cut during the shift for a very brief time. The fuel is not cut, so for a few engine revolutions, fuel is being sent thru the injectors, in and out of the cylinders, and out the exhaust, without being burned. Then, when the ignition is switched back on, the unburned fuel in the the exhaust system is ignited by the fresh hot exhaust and produces an obvious pop or bang. Very normal.
