Question About Torque Converter Replacement
Old Jun 6, 2021 | 06:02 PM
Pjmc15Z51's Avatar
Pjmc15Z51
Default Question About Torque Converter Replacement
I’m reading the shop manual about torque converter replacement on my 2015 A8 and it details removing the torque tube as part of the process. Is that the normal process or can the transmission be removed while leaving the torque tube in the car? This will be my first time. TIA
Old Jun 6, 2021 | 07:59 PM
RonC7's Avatar
RonC7
Don't know. But if you remove the torque tube, follow this procedure when you reinstall - otherwise the engine thrust bearing can be damaged:
https://www.corvetteactioncenter.com...dure-1313.html
GL
Ron
Old Jun 8, 2021 | 04:18 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I always leave the TT in the car. Can easily unbolt all the BH bolts from the TT by letting it swing down a bit. Just be careful with your angles so that you don't smack the engine into the firewall.
Old Jun 8, 2021 | 08:30 AM
99vetteran's Avatar
99vetteran
Phil thats good information. What do you think a good aftermarket converter is worth tuned properly. Would you say a couple tenths? Maybe a 2800 to 3000 stall that still drives good on the street.
To Question About Torque Converter Replacement
