C7 LT1 Knock sensor location
Old Sep 3, 2021 | 01:30 AM
Minchello's Avatar
Minchello
Default C7 LT1 Knock sensor location
Got a check engine light that i have a faulty knock sensor. Going to replace it. Where are they located on the LT1 Engine?
Old Sep 3, 2021 | 05:18 AM
Keihin39's Avatar
Keihin39
Hi rh side above starter on block LH side above oil filter under silver heat shield.
Old Sep 3, 2021 | 08:59 AM
Natas516's Avatar
Natas516
Cruising
I attached the locations.
File Type: pdf
Natas516's Avatar
Natas516
Cruising
Second knock sensor
To C7 LT1 Knock sensor location
