Soft grooves in rotors
both fronts have soft but not rigid grooves in the inside and outside face of the rotors, the rotors measure 1.3 thick. Pads are very low but not past the wear grooves yet. I have no issues with breaking, car drives and stops normally
So you think the thinness of the pad was the cause, are these rotors grind-able? I know the Levine auto shop near me does offer that service still.
Just think about it once the pads get down so much the pad is glue to the back of a piece of metal that will hold heat more with less pad. Then that is what I was told that small uneven groves come in at before it gets down to metal to metal.
Plus you don't want to just to new pads on the car with those uneven groves in the rotor if you do the pads will wear out faster & you will not get a good pull down due to the groves. Robert
Check the thickness of your pads with a gauge. The slot in the pad may or may not represent the true wear. If the pads are above 2/32 thick you have more life in them. I wouldn't bother turning the rotor.
Bill
Bill
Bill
i am not following, are you saying the wear pattern is normal? The rears are smooth with no grooves. The pads are at .17” thick which is about 1/32 shy of 3/16”
Replace the rotors if the grooves start to disappear or you get a crack that goes to the edge.
i am going to keep them and put new pads on.
the rotors have plenty of thickness left. I am putting on new carbotech pads for the track and street. Hope all goes well.
Here is a link to an article that describes issues and concerns related to AP Racing Brake Rotors. The groove is mentioned near the bottom of the article: https://www.essexparts.com/news-blog...-my-iron-discs
This is a copy of that section:
GROOVE IN THE CENTER OF AP RACING J HOOK DISCS
It's not at all uncommon for AP Racing J Hook discs to develop a groove or ridge in the center of the disc where the J Hook slots converge (see pic below). That groove is a result of the J Hook slot design. We see it all the time across all applications, and it doesn't in any way impact performance.
Here's why it happens: If you notice where that ridge forms on the disc face, it's at the termination of the J Hook slots. The pad material that gets scraped off the pad with each rotation disc rotation fills up the slots. If you think about the direction the disc is spinning, the 'back' of the J hook (the arced part) is leading into the pad. That pad material then exits at the tapered ends of the slots (see the red arrows in the image below). In the spot where that groove is, you're getting pad material exiting from both ends of adjacent J Hook slots. In other words, at that spot in the center of the disc face, you have pad material exiting the 'top' of the J from the slot closest to the hub, and the 'bottom' of the J on the adjacent slot closest to the OD of the disc. As that pad material exits the slots, it rides along under the pad squeezing the disc, and digs a little groove into the disc face.
There are many thousands of J Hook discs in circulation at all level of motorsport, and we've never had a premature failure or performance problem in any way related to this type of groove forming on a disc. That includes winning the NASCAR Sprint Cup championship 8 out of the past 9 years, winning Le Mans 8 times since the year 2000 on the factory Corvettes, and a host of other championships. The groove looks a little funky, but that's about it...nothing at all to worry about.
Despite a lot of shop mechanics with no experience of what happens in the racing world getting heart palpitations over the grooves, there isn't an issue.
Bill
