AWE AFM Valve Simulators
Old Oct 1, 2021 | 03:34 PM
'16 Z51 Vette's Avatar
'16 Z51 Vette
Default AWE AFM Valve Simulators
So I just ordered the AWE axle back exhaust for my 2016 z51. I don't believe the package is going to include the Valve Simulators. The shipping information is telling me that it should arrive tomorrow. So I quickly ordered the Valve Simulators however they are from a different company. They likely are not going to arrive at the same time. I know that installing the exhaust without the Valve Simulators can cause a check engine light. My question would be that if I install without the Simulators until they arrive will that cause any other issues or when they arrive can I just install them and clear the codes with my scanner?
Old Oct 2, 2021 | 03:00 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
You can install the simulators after.
-Josh
Old Oct 2, 2021 | 08:34 PM
Dcasole's Avatar
Dcasole
You can only clear the code with a deep scanner like GM's GDS2 or a similar tool . Run of the mill code scanners will not clear the code
Dave
Old Oct 3, 2021 | 08:47 AM
ErnieN85's Avatar
ErnieN85
Dave
so if you have an emissions check (test) don’t run it until the simulators are installed
Old Oct 4, 2021 | 11:29 AM
Patfitz9's Avatar
Patfitz9
It's much easier to place the actuators with simulators attached when the exhaust is out of the way. Sure it's possible to install after, but I'm not seeing a reason to do it in your case, only to get the exhaust on a day or two earlier.
To AWE AFM Valve Simulators
