No Electrical Power
Old Nov 5, 2021 | 06:16 PM
wradcliff's Avatar
wradcliff
Default No Electrical Power
Sunday I started to open the door on my 2016 Stingray. It wouldn't open. I opened the hatch plugged in the Ctek battery tender. After a day and a half hadn't been charged. In fact, the error light lit up. I resent the mod and the same happened. I got Auto Zone to replace my 17-month-old Odyssey battery. Replaced the battery and no power. What would cause the entire body power to go dead? Is there a master power fuse? I believe it was last driven in mid-September with no problems.
Old Nov 5, 2021 | 08:02 PM
Dcasole's Avatar
Dcasole
Yep 350 amp fuse right on the positive bracket by the battery , use a continuity tester to see if its good
Dave
Old Nov 5, 2021 | 10:10 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Yep that's the starter fuse. Direct feed to the starter. If that blew PM me I can show you how to fix it without having to spend hundreds on the entire fuse assembly.
Old Nov 7, 2021 | 12:33 PM
wradcliff's Avatar
wradcliff
My question is if it's that fuse attached to the positive side of the battery why did it blow? I last drove the car in early to mid-September. I got sick and was in the hospital in early October and spent most of October recovering. On October 31st I planned on taking a drive but the door wouldn't open!!! So I hooked up my Ctek battery tender.
Tomorrow it's being taken to the local Chevy dealer. If it is that 350 amp fuse my question is what caused it to blow? I want the Chevy dealer to address the root cause. You see it's a 2016 with roughly 23,000 miles. It's covered by the Platinum Plan GM Extended Warranty. It's because of the array of extensive electronics in the C7 that I purchased that warranty.
Thank you for the insight you have provided me.
Bill Radcliff
Old Nov 8, 2021 | 09:08 AM
Zjoe6's Avatar
Zjoe6
It shouldn't blow just from trying to open the door. Pretty easy to do a fuse check with a multi-meter.
Old Nov 8, 2021 | 09:19 AM
wradcliff's Avatar
wradcliff
I hate to admit between my buddy and me we didn't have all of the connections at the battery securely tightened.
Yesterday afternoon I was out fooling around. I pressed on that mega fuse and I saw sparks. I went around and retightened all of the battery connections and I suddenly was good.
I greatly appreciate everyone's input and am embarrassed that between my buddy and me we missed a fundamental battery connection. I did this too often as a kid to make such a huge screwup!!!!
Old Nov 8, 2021 | 12:29 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Thanks for getting back to us with solution.
Old Nov 8, 2021 | 12:33 PM
wradcliff's Avatar
wradcliff
I sincerely appreciate everyone prompt and thorough replies to my inquiries.
Old Nov 9, 2021 | 09:48 AM
Zjoe6's Avatar
Zjoe6
I've seen this a lot here. It seems very easy to tighten everything and still not have good connections. Glad you figured it out.
To No Electrical Power
