Missing sensor on differential.
Old Nov 8, 2021 | 03:34 PM
Arben72's Avatar
Arben72
Default Missing sensor on differential.
Long story short I swapped diffs and lost the sensor for the new one. I’m having a hell of the time finding the part number for it. It’s on the lower left and I believe it has to do with the elsd hydraulics. I’ve had bad luck with the parts department getting correct parts in the past so I try to avoid using them when possible. Much appreciated.
Old Nov 14, 2021 | 11:06 PM
Bill Dearborn's Avatar
Bill Dearborn
You do know your local parts department can display all of the parts and where they go so all you have to do is say that is the one I want. That is easier than trusting somebody online or over the phone to guess which one you want. Your picture leaves a little to be desired as far as determining what you want. Does it go in the little black hole to the right of the whitish looking thing? What does the thing you are looking for look like?
Bill
