E85 Questions
Old Nov 11, 2021 | 08:09 AM
Travlee's Avatar
Travlee
Default E85 Questions
I have the mod bug biting me, but without breaking the bank by going SC. My current mods are, AFE intake, Soler TB, LG long tube, Borla ATAK. I started reading up on E85, it says that its cleaner, cooler, and obviously adds power and torque (average 40hp/50 tq from what I can find here). For those that have did this, can you give me the pros and cons of it that you experienced, I planned on talking to the shop about the conversion next time I go in for an oil change
Old Nov 11, 2021 | 08:16 AM
7LitreC5's Avatar
7LitreC5
I run E85 (actual E66 out of the pump) in my 17 ZL1, 19 Z06, and 18 Tahoe (6.2 engine). I have not experienced any problems or drawbacks in any of these other than a decrease in fuel mileage of about 16%.
Old Nov 11, 2021 | 08:18 AM
Travlee's Avatar
Travlee
I can deal with that, given it a dollar a gallon cheaper than 93 in my area
Old Nov 11, 2021 | 08:23 AM
Buddy A's Avatar
Buddy A
You won't gain anywhere near 40-50. On a NA application the gains will be minimal unless you are running high compression. On a SC application there are some decent gains.
Old Nov 11, 2021 | 08:40 AM
Travlee's Avatar
Travlee
thanks for the insight
Old Nov 11, 2021 | 08:55 AM
CraigStu's Avatar
CraigStu
I consider an 11.5-1 CR to be high compression.
Old Nov 11, 2021 | 09:05 AM
TJay74's Avatar
TJay74
So what you are saying is you dont run e85 and dont really know much about it?
On a modern N/A engine you will see around 20-30 gains at the wheels running E85, as said depending on the pumps in your area winter time E85 blends are in the E50-E75 range, summer time blends can be E65-E80. Forced Induction vehicles can see nice gains, in the 50-100 HP at the wheels depending on the application.
Old Nov 11, 2021 | 09:31 AM
Gary barnes 1098's Avatar
Gary barnes 1098
On a modern N/A engine you will see around 20-30 gains at the wheels running E85, as said depending on the pumps in your area sinter time E85 blends are in the E65-E75 range, summer time blends can be E65-E80. Forced Induction vehicles can see nice gains, in the 50-100 HP at the wheels depending on the application.
what he said!! Gained 35 rwhp. Facts are facts.
Old Nov 11, 2021 | 11:06 AM
Internets_Ninja's Avatar
Internets_Ninja
E85 is a great mod for LT1's and LT4's. As mentioned you can expect at least 20-30rwhp on an LT1 with your mods. Just make sure your tuner knows how to verify your fuel system can keep up on E85. With your mods you will be on the edge of capacity on Pump E if it is high content (E75+) like it is in my area.
Old Nov 11, 2021 | 12:23 PM
Travlee's Avatar
Travlee
the shop will be 21st Century Muscle Cars, they did the work on my C6Z, and all the work on this C7
Old Nov 11, 2021 | 01:55 PM
99vetteran's Avatar
99vetteran
My first and easiest mod. Gained over 30 rwhp and my best with E85 (E65) was 11.58@120 and thats almost 1/2 second faster then my stock 12.06@116 on 93 octane. Plus it smells good, loving me some corn and with the combination of just a few other mods we've went 10.91@128, best et 10.90.
Old Nov 11, 2021 | 02:07 PM
aklim's Avatar
aklim
What exactly are you going to need to do to make a stock LT1 work with E85? Also, what happens if you don't have E85 around and have to use 93 or whatever?
Old Nov 11, 2021 | 02:32 PM
TJay74's Avatar
TJay74
You need the flex fuel sensor kit and someone to tune the ECM and or TCM for the changes (all of the changes are in the ECM, tune the TCM as well if you want even more improvement.). The ECM is able to "Flex" back and forth from gasoline to E85 in any ratio needed seamlessly. That is the beauty of the GM Flex Fuel system.
Old Nov 11, 2021 | 03:15 PM
99vetteran's Avatar
99vetteran
I just added the sensor, I'd never tuned on E85 so I had the initial tune done by someone else and I worked on the tune after that with my HP Tuners Mpvi2. Lots of logging to make the most power. Once I got to a certain point where I was not running any faster I contacted phil@phdtunging who is one our members and he really did some very fine tuning, mainly on the ECU but he did work more on the TCM for my drag strip tuning and we finally broke into the 10s. I think with good air and a prepped track it will go low 10.80s or maybe high 70s. I had the cool air and low DA a couple weeks back but the track really sucked. Never could hook so after 2nd pass loaded up and came home.
Old Nov 11, 2021 | 06:36 PM
Travlee's Avatar
Travlee
What have yall been paying for install and tune?
Old Nov 11, 2021 | 07:12 PM
Gary barnes 1098
I did install myself fairly easy. I bet they charge you 2 hrs labor,sensor about 300$ and tune around 500$.You’ll have a grand in it but worth it.
Old Nov 11, 2021 | 07:23 PM
Travlee's Avatar
Travlee
I was kinda assuming $1200, hope that is on high side. Appreciate the response sir
To E85 Questions
Old Nov 11, 2021 | 07:42 PM
99vetteran's Avatar
99vetteran
Mine was 350.00 for the dsx and 200.00 for the install and since I had my own Hp Tuners that I brought with me and had credits the tuner just used my lap top and credits and charged me 275.00 for tuning including dyno and since he'd done a lot of E85 Camaro and C7 tunes in took him about an hour or so. I was happy with that since the total was just a tad over 800.00. I was happy with that for a 1/2 second and 4 mph in the 1/4 mile times.
Old Nov 12, 2021 | 10:17 AM
2ZORNOT2Z's Avatar
2ZORNOT2Z
If they haven't tuned the car before it's usually around $650 - $800 for a flexfuel tune around here. You should have them tune it on 93 and then move to E85 imho but talk to your tuner about that. The sensor is $300 and maybe an hour of labor to install so $500 installed plus the tune. It's the best bang for the buck mod out there though!
Old Nov 12, 2021 | 10:36 AM
Internets_Ninja
If you own your own HPTuners license and laptop I do remote tunes for E85(well not just E85). The most economical way is to buy the sensor and install it yourself. There is plenty of info and youtube videos on it. Then pay a remote tuner to tune for you. If you don't own HPTuners and don't have the ability to install the sensor yourself, then the best bet is to find a shop local to you to do it all.
