tps c6 c7 compatable ?
Old Nov 18, 2021 | 01:42 PM
tonycorvettes's Avatar
tonycorvettes
Default tps c6 c7 compatable ?
my son has a 2008 conv i have a 2014 conv we are swaping wheels tires and tps will the tps work if reprogramed or will we have tp pulll them and swap? thanks tonycorvette@aol.com
Old Nov 18, 2021 | 02:00 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
My records indicate different part numbers. I'd swap the TPMS on the cars.
Elmer
Old Nov 18, 2021 | 03:46 PM
Maxpowers's Avatar
Maxpowers
I recall other threads saying they are not compatible.
Old Nov 18, 2021 | 03:47 PM
rwilson3944's Avatar
rwilson3944
C6 run I believe at 315Mhz and C7 is 433Mhz. So they would be unable to communicate to the new location.
Old Nov 19, 2021 | 11:56 AM
tonycorvettes
they both are 315
Old Nov 19, 2021 | 01:00 PM
rwilson3944
I know on my 2015 it's 433mhz. And my son's 2009 C6 is 315mhz.
Old Nov 19, 2021 | 03:02 PM
eboggs_jkvl
Moderator emeritus
Originally Posted by tonycorvettes
they both are 315
I believe they use dfifferent frequencies are are not compatible.
Elmer
Old Nov 19, 2021 | 04:38 PM
EVRGRN's Avatar
EVRGRN
Elmer
Old Nov 20, 2021 | 12:41 AM
HOXXOH's Avatar
HOXXOH
C6 cars built for foreign markets use the 433 mhz freq, but all other C6's use 315 mhz.
Old Nov 21, 2021 | 12:26 PM
daveb91's Avatar
daveb91
they both are 315
No c7 is 433
Old Nov 21, 2021 | 03:14 PM
ss2z06's Avatar
ss2z06
Are not interchangeable. As mentioned different frequencies
Old Nov 21, 2021 | 03:22 PM
RacerRik's Avatar
RacerRik
Not only are the TPMS sensors incompatible, but the C6 wheels will not work on your C7. The spokes will hit the calipers on the front wheels.
Old Nov 22, 2021 | 12:59 AM
HOXXOH's Avatar
HOXXOH
C6 gumbies will clear C7 base calipers.
Old Nov 22, 2021 | 01:20 AM
RacerRik's Avatar
RacerRik
I tried to use a friends C6 gumbies on my 2018 Base C7. The spokes hit the front calipers on my car. Did GM change to larger brakes on later C7s vs earlier C7s?
Old Nov 22, 2021 | 07:34 PM
Smokeyjr's Avatar
Smokeyjr
Emerging Vendor
They are (tpms) "not" compatible...tried it...didn't work!!
Old Nov 22, 2021 | 07:41 PM
RacerRik's Avatar
RacerRik
Originally Posted by Smokeyjr
They are "not" compatible...tried it...didn't work!!
Glad I am not the only one that tried it and found out they will not work. It was close - so maybe if you used some wheels spacers.... I would personally not use wheel spacers on my car but to each his own.
To tps c6 c7 compatable ?
