Rear axle, stabilitrack, CEL.
Old Nov 24, 2021 | 01:24 PM
Iverr6's Avatar
Iverr6
Default Rear axle, stabilitrack, CEL.
Took the car out today ('17 Z06 3k miles), noticed rough idle at first, then significant performance reduction followed by what felt like a wobble in the feel of the ride. Soon after that the CEL came on, stablitrack, and rear axle light, so I immediately took the car home. I do drive this car on a regular basis so it wouldn't be a issue of it sitting for long periods of time. Mechanic seems to think it is most likely a injector or coil issue. Has anybody experienced this?
Old Nov 25, 2021 | 03:41 PM
Silvah Goat's Avatar
Silvah Goat
Yes like 5 times. First time was a bad plug wire/plug when the car was nearly stock. Basically any time the car starts hard, I get those messages.
Old Nov 25, 2021 | 07:04 PM
Theron4569's Avatar
Theron4569
Had something similar when my battery was going bad. Replaced the battery and all was fine.
Old Nov 26, 2021 | 08:52 AM
Tinkertech's Avatar
Tinkertech
Try reading the DTC (diagnostic trouble codes) with a scanner.
Good starting point.
Go from there.
Old Nov 26, 2021 | 05:32 PM
Bill Dearborn's Avatar
Bill Dearborn
An engine code triggers the Stability and Rear Axle messages/codes since they depend on a properly operating engine to work properly. If there is anything indicating the engine can't control torque properly when another module requests a change in torque output the module requesting a change will shut down and set a code.
Bill
Old Nov 26, 2021 | 06:38 PM
Silvah Goat
Bill
Yes that is definitely how they designed it to work. However, I have gotten it without any DTCs being set or pending. For over a week on every start then stopped on its own. Others have replaced their alternators and cleared up the issue with no DTCs.
Old Nov 29, 2021 | 11:14 PM
Iverr6's Avatar
Iverr6
Got it to the shop today, hopeful they will figure it out. Ill post what the problem ends up being.
Old Dec 1, 2021 | 02:45 PM
RichAshley-Black99's Avatar
RichAshley-Black99
Yep just had the same issue on mine (15 Z06), ended up being the injector on cyl 4. We went ahead and replaced all 8, as well as new plugs, wires etc.
-Rich
To Rear axle, stabilitrack, CEL.
