2014 Wet Sump Engine Replacement. 2015 compatible?
Old Jan 12, 2022 | 02:23 PM
Chevy0818's Avatar
Chevy0818
3rd Gear
Default 2014 Wet Sump Engine Replacement. 2015 compatible?
Hello everyone I did about 10 minutes of searching the forum. Can anyone confirm the 2015+ LT1 wet sump is compatible in a 2014 wetsump. They were shown as 2 separate engines and harness. Just picked up my first vette with a broken valve spring. The valve fell in and cracked the block. They look similar but before I pull the trigger on a engine would like to confirm. My engine is complete so I can swap stuff over.
Last edited by Chevy0818; Jan 12, 2022 at 02:24 PM. Reason: Predictive text/fat fingers
Old Jan 12, 2022 | 09:56 PM
Moving this over to C7 Tech for some advice.
