Front Lower ball joint thread and pitch
Old Feb 11, 2022 | 10:33 PM
Travlee's Avatar
Travlee
Default Damaged Front Lower ball joint, anyone know thread and pitch
While changing out my front wheel bearings the lower ball joint threads got boogered up. Does anyone know the thread and pitch? I have a die set, but it won't go on straight, almost need the split apart one. Worst worst case, I guess I could change the ball joints
Old Feb 12, 2022 | 02:45 PM
ErnieN85's Avatar
ErnieN85
Just check the nut with a bolt at the hardware store
Old Feb 12, 2022 | 03:08 PM
Travlee's Avatar
Travlee
That's on my hit list, thanks for the reply sir.
I saw this, essentially you Dremel off the bad threads and cone it a little
Old Feb 13, 2022 | 04:21 PM
Travlee's Avatar
Travlee
Dremel worked... drivers side gave me a little harder time. Didn't have the proper die, but one was close enough to cut some threads to get it started. Damn it's nice to be driving the vette again, 2 weeks straight of the nissan juke was killing me
Old Feb 14, 2022 | 07:12 AM
Travlee's Avatar
Travlee
well ****... coming to work this morning on a sweeping right turn, there was a grind sound again. not sure what else to check
Old Feb 14, 2022 | 09:13 AM
ErnieN85's Avatar
ErnieN85
Start with checking all four wheel bearings (front & rear)
It is possible you got a bad new one. then look for bad bushings (probably not)
look for witness marks for rubbing also
Old Feb 14, 2022 | 12:51 PM
Travlee's Avatar
Travlee
link to the original post with the issue
https://www.corvetteforum.com/forums...ce-needed.html
To Front Lower ball joint thread and pitch
