Lt4 injectors
Old Mar 25, 2022 | 10:52 PM
jjones3376's Avatar
jjones3376
Emerging Vendor
Default Lt4 injectors
This maybe a stupid question but if you change to lt4 injectors can you get more fuel out of them once tuned over lt1 injectors.
Old Mar 26, 2022 | 01:19 PM
ss2z06's Avatar
ss2z06
not a stupid question. many people upgrade the lt1 to the lt4 fuel system which includes the DI injectors because of more potential.
Old Mar 26, 2022 | 01:31 PM
jjones3376's Avatar
jjones3376
Emerging Vendor
I ask because I need to eventually do aux pump and lt4 high pressure pump. But was goin to do lt4 injectors first. I am getting a retune in a couple weeks since I got tcm unlocked and went o e pulley size smaller on procharger.
Old Mar 26, 2022 | 11:07 PM
ss2z06's Avatar
ss2z06
I’d defer to your tuner but not sure it makes sense to do the injectors without the HPFP at the same time.
Old Mar 27, 2022 | 10:07 AM
Internets_Ninja's Avatar
Internets_Ninja
You can change just the LT4 injectors but keep an eye on the high side fuel pressure. If you try to push too far without the LT4 HPFP you will drain the rails and max out the LT1 HPFP.
Old Mar 30, 2022 | 05:05 AM
Joshinator99's Avatar
Joshinator99
LT4 injectors are designed to run 2900 psi. LT1 HPFP only operates at 2175 psi. No sense in doing the LT4 injectors without the matching HPFP in my humble opinion.
To Lt4 injectors
