No Start
Old Apr 2, 2022 | 09:40 AM
2ndvett01's Avatar
2ndvett01
Default No Start
2019 1lt: clicking noise when trying to start. Had it on Ctek maintenance for a couple of days . Did I mess something serious up?
Old Apr 2, 2022 | 09:50 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Probably not, but it does that when the battery has gone belly up and needs to be replaced.
Elmer
Old Apr 2, 2022 | 09:51 AM
laserdude2215's Avatar
laserdude2215
Old Apr 2, 2022 | 10:01 AM
2ndvett01's Avatar
2ndvett01
Thank You for reply. Battery less than 2 years. Don’t let it go more than 2 days off of Ctek. Bad Ctek?
Old Apr 2, 2022 | 01:26 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Bad CTek OR a parasitic draw !!
Old Feb 25, 2023 | 07:45 AM
JD1964's Avatar
JD1964
If 14.95 is the output, I agree it’s higher than it should be. Faulty components in the alternator can cause that. Faulty components in the alternator can also cause a parasitic draw when the car is parked and sitting. That might explain a dead battery.
Old Apr 5, 2024 | 10:51 AM
Dogmark's Avatar
Dogmark
No, give it a fast charge With an actual battery charger for an hour. That should do it.
Old Apr 5, 2024 | 12:12 PM
kodpkd's Avatar
kodpkd
Hopefully he got it fixed a year ago.
Old Apr 5, 2024 | 12:39 PM
Dogmark's Avatar
Dogmark
One can only hope!
Old Apr 5, 2024 | 07:05 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Dumb topic and should be in General anyway. Google is your friend!
To No Start
