Replacing SC Lid and Bricks Help
Old Apr 4, 2022 | 10:01 PM
Molly815's Avatar
Molly815
Default Replacing SC Lid and Bricks Help
2015 Z, just bought 2017 lid and cooling bricks. Can these bricks be installed without a tune?
Old Apr 5, 2022 | 10:29 AM
jglassmaker's Avatar
jglassmaker
Yes, you do NOT need a tune for just the lid and bricks.
What they change is lower the intake air temps which the computer uses to decide if it needs to take out timing. The hotter the air coming in the more timing is removed and less power - with the 2017 lid and bricks the air doesn't get as hot so you keep the timing and power.
Old Apr 5, 2022 | 08:42 PM
Molly815's Avatar
Molly815
Glad to hear this news, thanks for he info jglassmaker! I will install them this weekend then, cant wait to see if there is a difference in at least some power and the sound of the s/c whine.
Old Apr 5, 2022 | 09:05 PM
laserdude2215's Avatar
laserdude2215
Don't forget to remove the hood liner.
Old Apr 6, 2022 | 08:46 AM
Catfish4818's Avatar
Catfish4818
Here's my next educational opportunity - what's a 'cooling brick'?
Old Apr 6, 2022 | 08:58 AM
SwampDog13's Avatar
SwampDog13
He’s using the term interchangeably for the two intercooler cores.
Old Apr 6, 2022 | 01:51 PM
Catfish4818
Thanks, Dog.
Old Apr 11, 2022 | 04:29 PM
Bill Dearborn's Avatar
Bill Dearborn
It will not affect power or SC whine. I swapped a 2017+ SC into my 2015 Z two years ago. I didn't notice any increase in whine or power, You still have to bleed the SC properly for the bricks to provide the improved charge air cooling to cylinders 7 and 8. The bricks help reduce power loss Vs improve power.
Bill
Old Oct 12, 2022 | 12:36 AM
C7Z07's Avatar
C7Z07
1st Gear
How did the install go? Do the 17-19 bricks fit? What kind of modification are needed to make them fit?
Old Oct 12, 2022 | 02:37 PM
9sec's Avatar
9sec
you may need to drill out 2 of the mounting holes on the bricks to line them up too the supercharger.
and no you dont have to change the hood liner. the lid just barely touches it no big deal
Old Oct 13, 2022 | 08:58 AM
ZO6LIFE's Avatar
ZO6LIFE
There's a thread that details the full conversion procedure. Since the 2017 and up bricks sit differently in the SC housing, I think the only mod you'll need to worry about is mounting them in there. Lots of guys have done it. I would use the forum search.
To Replacing SC Lid and Bricks Help
