x pipe install
Old Apr 16, 2022 | 06:36 PM
Wujekcity's Avatar
Wujekcity
Default x pipe install
not sure how the npp is controlled in the exhaust, but if someone has a xpipe off road mod, is there a way that the npp could be disconnected or not properly done??
Old Apr 16, 2022 | 06:47 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I know AWE has AWE AFM Valve Simulators allow cars with AFM valves to equip AWE Axleback Exhausts without the worry of throwing a CEL
Old Apr 16, 2022 | 11:22 PM
96GS#007's Avatar
96GS#007
Nope. Changing the x-pipe has zero impact on NPP operation. There's no need to touch the actuators or any of the wiring when swapping the x-pipe and you barely have to wiggle the mufflers to free the old x-pipe or install the new one.
Did you check the fuse?
To x pipe install
