Couple issues after 15" rear conversion
Old Apr 22, 2022 | 09:00 PM
sick cc's Avatar
sick cc
Default Couple issues after 15" rear conversion
Just completed my 15" rear wheel conversion on my 2018 grand sport. Everything went smooth and I doubled checked everything after the install.
the cats been parked all winter and I did have to use the battery jumper to start sfter it was done.
during the first drive I had received the service e rear axle message, service parking brake dash light, brake dash light, and stabilitrack dash light.
evening else on the car seems good, it does have 25k miles and is on the original battery, could the battery be going south causing all the tech nannies to freak out or am I overlooking something simple after doing the conversion?
I appreciate any help!!
Old Apr 22, 2022 | 09:35 PM
jamieo's Avatar
jamieo
The battery is the first place I would start.They cause a lot of weird issues when the voltage gets low.
Old Apr 22, 2022 | 10:59 PM
sick cc's Avatar
sick cc
Good deal, I will be replacing that first thing in the morning, fingers crossed that's all the issue is!
Old Apr 23, 2022 | 10:22 AM
sick cc's Avatar
sick cc
Unfortunately the new battery did not resolve the problem, anything else maybe im not thinking of?
Old Apr 23, 2022 | 12:18 PM
Corvette4ever's Avatar
Corvette4ever
Alternator
Old Apr 23, 2022 | 01:55 PM
sick cc's Avatar
sick cc
Originally Posted by Corvette4ever
Alternator
I'm not doubting that, id just hate to buy one and find out it wasn't the problem ya know.
has that been the culprit in the past?
Old Apr 23, 2022 | 01:59 PM
jamieo's Avatar
jamieo
Not saying it isn't possible but a bad alternator usually shows a charge system fault.
Old Apr 23, 2022 | 05:24 PM
sick cc's Avatar
sick cc
Did a charging system check and all was very well there.
my ABS code is C0245.
anyone ever experience that one?
Old Apr 23, 2022 | 07:14 PM
douniasg's Avatar
douniasg
I would triple check your sensors that screw in the spindles and connections. That is the only thing that gets removed during the spindle change and could cause that.
Old Apr 23, 2022 | 07:30 PM
Corvette4ever
My car had similar symptoms plus other things. Had to monitor the voltage in HPT scan and found it fluctuating between 16-12 volts . Replaced the alternator and the reading became a straight line at 14.2-14.3 volts
Old Apr 23, 2022 | 09:53 PM
sick cc's Avatar
sick cc
All linkage and ABS sensors were triple checked.
during a log with a scanner I verified the connection did not skip a beat for the weeks sensor speeds when the lights would activate while driving.
at this point I'm almost certain it's either the tire size combo that I'm running, 325-50-15 and 225-40-18's OR the fact that I do not have any TPMS sensors installed.
I will however log tomorrow with hp tuners to double check to male sure my voltsge isnt fluctuating out of range.
Old Apr 23, 2022 | 10:20 PM
jamieo's Avatar
jamieo
Tire Size Comparison
Way too much difference!
Old Apr 23, 2022 | 10:26 PM
sick cc's Avatar
sick cc
Yeah there's a pretty big difference between the two, with the rear big alot larger in diameter. Hence why the rear rotates alot less than the Fronts, causing it to think there is a "brake malfunction" causing drag or lock up and throwing the codes.
this is my best assumption but again I have no physical way to verify since I no longer have any stock wheels lol
Old Apr 24, 2022 | 09:37 AM
Gary barnes 1098's Avatar
Gary barnes 1098
I’m betting on this.
Old Apr 24, 2022 | 10:10 AM
123sugey's Avatar
123sugey
Dig
Your going to have to get taller front tires
Old Apr 27, 2022 | 08:08 PM
sick cc's Avatar
sick cc
Problem resolved
I went from a 225/40-18 up to a 225/45-18. This made the tire size ratio front to rear about one inch closer and has solved the issue.
thanks everyone, wanted to make sure i posted the fix incase someone else runs into the same issue.
Old May 6, 2022 | 10:29 PM
twinstang's Avatar
twinstang
Problem resolved
Glad you got it figured out. So now where are the picture's with the the 15's on!!
To Couple issues after 15" rear conversion
