Need bolt torque specs
Old May 5, 2022 | 06:41 PM
tymerr's Avatar
tymerr
Default Need bolt torque specs
Does anyone have a post of a complete list of bolt torque specs for the c7 z06? Looking for Engine Mounts to block and stud that the mounts go in on each side. Also looking for torque specs on the AC Compressor Bracket and the last one is the bell housing bolts?
Old May 5, 2022 | 06:49 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If the information you seek is not in here, you can probably get the information to the specific situation by asking for the specific activity you are doing.
https://www.corvetteforum.com/forums...-stingray.html
Elmer
Old May 5, 2022 | 08:05 PM
ss2z06's Avatar
ss2z06
https://paceperformance.com/files/pd...rque-specs.pdf
Old May 5, 2022 | 09:03 PM
tymerr's Avatar
tymerr
Thank you. It just says engine mount, does that mean brackets to the block or the single stud sticking up the motor mount sits on?
Old May 5, 2022 | 11:26 PM
96GS#007's Avatar
96GS#007
For $20 you get 3 days access to the GM manuals...
https://www.acdelcotds.com/subscriptions
What you need is towards the bottom of the page:
General Motors Service Repair Manual Information (does not contain software)
Campaigns & Bulletins from 1980 to present
Unit repair manuals from 1997 to present
Service manuals from 1996 to present
Owner manuals from 2003 to present
Old May 6, 2022 | 11:40 AM
Jeff V.'s Avatar
Jeff V.
For $60 you get the same information for a year. The price increased recently, but they massively updated the site. It's a lot easier to use now. The information is identical to what you get on the GM website.
https://www.alldata.com/diy-us/en
Old May 6, 2022 | 12:11 PM
tymerr's Avatar
tymerr
Thanks everybody! Just purchased a subscription.
Old May 6, 2022 | 12:29 PM
Jeff V.'s Avatar
Jeff V.
For someone who only does occasional small projects, it's probably not worth it. But with as deep as it sounds like you're going, it'll pay dividends immediately.
Good luck with your project!
Old May 6, 2022 | 09:19 PM
tymerr's Avatar
tymerr
74 ft lbs seems a little excessive. Anyone else? Is this correct?allation Procedure Caution: Refer to Fastener Caution.
  1. Install the engine mount bracket (2).
  2. Install the engine mount bracket bolts (1) and tighten to 100 Y (74 lb ft).
  3. Using ONLY hand tools, install the crossmember mounting fasteners and tighten to 160 Y (118  lb  ft).
  4. Remove the J-33432-B compressor from the transverse spring.
  5. Remove the transmission jack.
Old May 7, 2022 | 02:17 AM
96GS#007's Avatar
96GS#007
This thread may help you: https://www.corvetteforum.com/forums...pecs-help.html
If you're talking about the nuts that secure the engine mount to the cross-member.....43 lb ft as also mentioned by ss2z06
Old May 7, 2022 | 02:27 AM
tymerr's Avatar
tymerr
Bolts that attach brackets to the block. The 3 15mm bolts on each side
To Need bolt torque specs
