Torque tube anyone
Old May 9, 2022 | 10:08 AM
bikemiser's Avatar
bikemiser
Default Torque tube anyone
I posted on C7 general forum, maybe the wrong place, I'll try here.
I understand there is an inspection port at front of torque tube. How much can actually be analyzed like bearing, coupler, flex plate, etc., thru that opening? Thanks for any comments, Jim
Old May 10, 2022 | 07:28 AM
GSCE#456's Avatar
GSCE#456
Following
Old May 11, 2022 | 05:47 PM
3X2's Avatar
3X2
No inspection port tha tI am aware of. If you want to see the couplers and bearings, etc, the drive shaft needs to be removed from the torque tube.
Old May 12, 2022 | 01:25 PM
djyankees31's Avatar
djyankees31
To inspect, remove the rubber cap on the bell housing. Use your phone or borescope inspection camera. If the drive shaft bearing is recessed more than a 1/4 inch in the torque tube then it's bad.
I just finished replacing my torque tube and converter using a quick jack and a couple of harbor freight transmission jacks.
To Torque tube anyone
