Mail order Tuner help
Old May 23, 2022 | 06:04 PM
DrLs7's Avatar
DrLs7
Cruising
Default Mail order Tuner help
Does anyone know of a tuner that can do a tune with handheld? I am doing boltons for now and gonna get dyno tune in 2 months after heads, cam, intake swap. Any help appreciated.
Old May 23, 2022 | 08:48 PM
14point5's Avatar
14point5
Cruiser
Veteran: Marine Corps
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
I use the inTune Diablosport handheld tuner.
Diablosport
There is a forum member who goes by "Diablo-Lew" who can supply custom mail order tunes for use with Diablosport products.
Old May 23, 2022 | 08:54 PM
DrLs7's Avatar
DrLs7
Cruising
Thank you, i just ran across DSP Performance Motorsports, have worked with the owner in the past and was really satisfied with my results.
Old May 24, 2022 | 12:16 AM
aklim's Avatar
aklim
Are they doing the dyno tune or datalog tune? Or are they just drop shipping something off the shelf?
Old May 24, 2022 | 07:19 AM
DrLs7's Avatar
DrLs7
Cruising
Just off the shelf, i live in Middle Tennessee and my dyno tuner is in Ga. This works out good for me to be able to drive it down when ready to put it in the dyno. I will say though, my bolton C5 that was tuned by this guy was dead on.
Old May 24, 2022 | 02:35 PM
Blackwater0323's Avatar
Blackwater0323
Used Lewis Eaton (diablolew) and he is great. I did a few things on my car and had him upgrade my tune-CAI first, Soler/TB Controller second, then x-pipe cat delete. Have to be patient as you start with a log, upload his tune, then verify by logging a 0-1/4 mile through the gears and sending it back. Then you have drive 100 miles and send another log for verification. He actually said I was getting knock and I saw it on the data log on my computer. He mentioned the brand of 93 that I was using was notorious for knock. Switched to non-ethanol 93 mobil and no more knock showing on the data log. Just for kicks, I turned the tune back to stock and the car felt a lot slower. His service is worth the money. You have 1 year to get it done.
Old May 24, 2022 | 04:36 PM
aklim's Avatar
aklim
Wonder why. Ethanol doesn't reduce octane, does it?
Old May 24, 2022 | 05:17 PM
jamieo's Avatar
jamieo
Lew also had knock on mine while data logging.Switched fuels and nothing else and knock went away.Don't want to list a name on here but he strongly urges against one particular brand.
Old May 24, 2022 | 08:17 PM
KemahGT's Avatar
KemahGT
If you’re going to be doing heads/cam etc., chances are your dyno tune will be done by someone with HPTuners. I would start with HPTuners and get an email tune from one of the recommended tuners on this forum.
Old May 24, 2022 | 08:28 PM
aklim's Avatar
aklim
Why? If it is bad, we should know about it. PM me if you feel inclined to go that way. Thanks
Old May 24, 2022 | 08:29 PM
aklim's Avatar
aklim
Wouldn't the package be better if it was by the tuner? IOW, go with what the tuner recommends and dyno tune it as opposed to getting a package together and ask the tuner to make it work?
Old Jul 5, 2022 | 01:43 PM
Blackwater0323
Shell
Old Jul 5, 2022 | 03:18 PM
Internets_Ninja's Avatar
Internets_Ninja
Shell fuel seems to knock more regardless of another Top Tier brand with or without ethanol. I have seen Shell 93 fuel be more prone to knock than any other top tier fuel. E0 93 octane and E10 93 octane are the same in regards to knock resistance so there isn't a need to go finding non ethanol fuel. Just run another Top Tier like Exxon, Mobil, Sunoco, Chevron, etc...
Old Jul 8, 2022 | 01:29 PM
Thomasmoto's Avatar
Thomasmoto
Get in touch with Alex Peitz at Pietz Performance Tunes. He trains for HP Tuners regularly and can tune pretty much everything. PM me for the number if you want it..Tell him Dave Thomas from Greer, SC that told you about him. He did my 16 Z06 that's my avatar.
To Mail order Tuner help
