C7-C6 Z07 Calipers
Old Jun 5, 2022 | 10:53 PM
olblue75's Avatar
olblue75
Default C7-C6 Z07 Calipers
Anyone know what the differences are between the C7 and C6 Z07/CCM front brake calipers?
Old Jun 5, 2022 | 11:31 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i think it may be the different spacing between the mounting tabs.
Old Jun 7, 2022 | 04:53 PM
Bill Dearborn's Avatar
Bill Dearborn
If there is any difference it is in the mounting of the calipers. Otherwise, they use the same brake pads (other than the C6 pads have a shorter wiring harness for the wear sensor). The rotors are the same size and offset with the only difference being the C6 rotor hat doesn't have a bolt that holds the rotor to the hub. The C7 rotor has that bolt that doesn't really provide any useful function once the car has left the factory unless you consider freezing into place and requiring drilling of the rotor hat before removing the rotor useful. .
Bill
To C7-C6 Z07 Calipers
