Checking 2016 automatic oil level
Old Jun 10, 2022 | 06:53 AM
Daleford's Avatar
Daleford
Default Checking 2016 automatic oil level
I am not a mechanic and new to the C7, so bear with me. I need to check the oil level in my 2016 automatic transmission. In obtaining the proper trans temperature, if I drive the car to my mechanic's shop [20 miles] would the temp possibly be too high? Can I read the transmission temperature on the dash somewhere?
Old Jun 10, 2022 | 07:39 AM
Dcasole's Avatar
Dcasole
If it's to high driving normal then you have problems. , yes you can read the temp on the dash
Dave
Old Jun 10, 2022 | 09:04 AM
Daleford's Avatar
Daleford
Dave
There is always a lot of talk about doing the check after bringing the temp up to an exact level so I assumed highway driving for 20 miles might take the temp beyond that desired number.
Old Jun 10, 2022 | 09:56 AM
Dcasole's Avatar
Dcasole
also long as nothing is wrong with your trans it should be operating at the desired temp for checking. U will be ok
Before driving you did check it once already right if not you could be over filled
Dave
Old Jun 10, 2022 | 12:05 PM
Daleford's Avatar
Daleford
Dave
OK so driving temp is about the same as checking temp. Understood. Plus I know now I can monitor it on the dash.
Yes we checked it already
Old Jun 10, 2022 | 08:32 PM
Bill Dearborn's Avatar
Bill Dearborn
From the 2015 Factory Service Manual:
Bill
To Checking 2016 automatic oil level
