Fender Liner Bolt Question
Old Jun 14, 2022 | 03:44 PM
SFwoc's Avatar
SFwoc
Default Fender Liner Bolt Question
HI Forum Members - can anyone tell me whether the bolts that connect the front fender liners behind the wheel and underneath the doors, require a corresponding nut to bolt into or do they connect to the body directly? The specific bolt that I am referring to is item #13 in the picture below (the one highlighted by the red square) that I believe the part number is a M6x1x22 Multi-Purpose Bolt 11609982. There is no nut shown in the schematic from GM and unfortunately I'm away from the car and can't take a look at the other side before I order.
Thanks in advance for your thoughts and insights.
Old Jun 14, 2022 | 04:09 PM
ErnieN85's Avatar
ErnieN85
never looked for a nut seem to work without or are captive
Old Jun 14, 2022 | 05:28 PM
Jeff V.'s Avatar
Jeff V.
I'm pretty sure those use a u-nut on the body side. Similar to this:
Old Jun 14, 2022 | 09:23 PM
tiborrules's Avatar
tiborrules
That is correct. It is the u net shown. I've replaced my fender liners due to tire rubbing on track days.
Old Jun 15, 2022 | 06:10 PM
SFwoc's Avatar
SFwoc
Thank you all for the insights
Old Jun 20, 2022 | 03:58 PM
the blur's Avatar
the blur
I replaced my fender liner, and now have an extra 10mm bolt. No idea where it came from....
Old Jun 20, 2022 | 04:35 PM
ErnieN85's Avatar
ErnieN85
Better than one short, check under at the front there several there
Old Jun 20, 2022 | 09:22 PM
96GS#007's Avatar
96GS#007
as well as under the rear. As I recall...assuming you're talking about the front liner...there's one that's aft of the control arms about midway up on the liner that's easy to overlook.
To Fender Liner Bolt Question
