Ctek problem
Old Jul 4, 2022 | 08:23 AM
2ndvett01's Avatar
2ndvett01
Default Ctek problem
2019 Stingray 1lt: connected Ctek model US 7002 using socket in rear compartment. Green light came on meaning battery fully charged. Checked it two days later. No green light. Tried to start car. Only got the dreaded clicking. Anyone experience this with Ctek? Bad Ctek
Old Jul 4, 2022 | 09:14 AM
Michael_A's Avatar
Michael_A
Ctek probably fine, but the damn plug is likely the problem. For some reason, the plug that is on the OE Ctek charger is super finicky about being inserted into the charging port and making a good connection. I have several other chargers that have cigarette lighter plugs and none of them are as fussy as the Ctek's. I quit using the OE Ctek when I put an Optima battery in the car and have been using a Optima charger with no issues whatsoever. I plan on cutting the end off the Ctek (the cigarette lighter plug is permanently attached to the cable on the OE chargers) and replacing it with a standard 2 pin plug like a Batterytender and using it on other vehicles at some point. I suspect Ctek uses the same cigarette lighter plug in all of their applications, so even if you don't have the OE charger you may still have the same jicky connection issues. If your Ctek has a 2 pin cable connector you may just want to try a different plug that you can get at any auto parts store.
Old Jul 4, 2022 | 12:12 PM
Jeff V.'s Avatar
Jeff V.
I've had the same problem with my Corvette branded CTEK. Never had the problem with my Battery Tender Jr or my Harbor Freight charger. The plug sometimes walks itself out just a hair, resulting in a poor connection. I'm going to do what Michael suggested and just put a different end on it.
Old Jul 4, 2022 | 12:16 PM
2ndvett01's Avatar
2ndvett01
Me too.
Old Jul 6, 2022 | 08:30 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
The CTEK I used with my C6 never had a problem and the one I have with my 19 has been in use for 3 1/2 years with no issues. Hope you can resolve your issue.
Old Jul 6, 2022 | 09:22 AM
ersatz928's Avatar
ersatz928
A loose plug would not have resulted in a dead battery.
The CTEK circuitry died and discharged your battery "backwards" through the 12V plug.
CTEK = junk
Buy a Deltran Battery Tender.
Old Jul 6, 2022 | 11:27 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
This is certainly not what we like to hear, 2ndvett01. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 Stingray 1lt. To do so, please send an email to socialmedia@gm.com with ATTN: 2ndvett01/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Old Jul 6, 2022 | 03:38 PM
iclick's Avatar
iclick
Several months ago the lighter connection in the hatch stopped working, more than likely because of a blown fuse. Like many have reported here over the years I've also had trouble with the finicky stock CTek connector, and instead of pulling carpet and hassling with the rear fuse box I did as you contemplate, which was to cut the CTek wire at the connector and install a Deltran BT connector in its place. When I replace the car's original battery I will take a look at that fuse. I used two large alligator clips to connect directly to the battery, and be aware that on the battery end the positive lead goes to the shielded part of the Deltran connector.
I cut the wire again to install two blade connectors so I could swap the Deltran and CTek connectors if I decide to do that in the future, which probably won't happen. It works fine, and the only downside is that the Deltran requires two hands to connect while the CTek only one.
If you go with the blade connector idea, make sure you swap the male and female on each end so that you can't plug them in with the wrong polarity. Will shoot a pic if anyone needs clarification.
Old Jul 10, 2022 | 11:09 PM
wrecker3's Avatar
wrecker3
Get a Deltran Battery Tender !!! I have been using them since my first 1987 C4 and have had batteries last 10 years !!
Old Jul 11, 2022 | 08:30 PM
iclick's Avatar
iclick
I agree and have had BT+ for 17 years that has been used on numerous cars, motorcycles, and lawn tractors I've owned in that time frame. It has survived many indignities, including being run over by my Harley more than once, and still serves as the full-time maintainer for my truck. I also had a BT Jr., which I stupidly let go with my last motorcycle, and a solar BT that I use on my ZTR mower in a shed that has no AC power. OTOH, if you already have a CTek, which in my case was part of my GS package, you can fix the quirky lighter setup with the easy mod mentioned earlier. If I didn't have a maintainer and wanted to buy one I'd probably go with the BT Jr., which is economical and quite up to the task.
Old Jul 14, 2022 | 12:23 AM
Avanti's Avatar
Avanti
I've the GM supplied Ctek I've used on my C7 since new (5-years) with no issues. However, I make sure the socket is well mated via a twist and double-push at insertion. Plus, I close the hatch, but make sure there is extra cord in the car so as not to pull tight and dislodge on closing. Now for Battery Tenders... all is not perfect there, either; I assure ya. I've 7 or 8 I've bought over the years and still use a few for my "fleet." Three just flat-out died over the time I've used them. I also have an expensive Optima charger, since there was a time before the company was sold that I only used their batteries in my collector and sports cars (no more, btw) and it has always worked fine for everything ranging from lawn-mower batteries, to motorcycles, to assorted car and truck batteries, including one ancient Optima that just won't die. The moral... is like with our Vettes; anyone can get a bad one occasionally, but most are very good. All the best.
To Ctek problem
