Noise Reduction Removal
Old Jul 20, 2022 | 09:31 AM
Buddhaman's Avatar
Buddhaman
Default Noise Reduction Removal
I was reading through this thread (https://www.corvetteforum.com/forums...to-finish.html) and noticed that it was recommended to remove the pins for the noise reduction microphones from the X3 plug. I know that was in regards to adding an additional amp and subs but was curious if removing them from a stock 10-speaker system would cause any issues or provide any improvements. Anyone have any experiences with this?
Old Jul 20, 2022 | 12:44 PM
ersatz928's Avatar
ersatz928
It will only make the interior noise level higher.....
Old Jul 20, 2022 | 02:21 PM
Internets_Ninja's Avatar
Internets_Ninja
You're only supposed to remove them in some scenarios when adding an external amp, sub and speakers. The noise cancelation messes with the aftermarket pieces or causes additional weird noise problems.
Old May 4, 2023 | 11:53 PM
Rbohno's Avatar
Rbohno
That would be me so is pulling pin 4 and 5 the way to go?
Old May 8, 2023 | 01:08 PM
ersatz928's Avatar
ersatz928
Yes, pin #4 and pin#5 will disable the noise cancelling feature.
To Noise Reduction Removal
