Display turns dark a lot
Old Aug 10, 2022 | 07:57 PM
Chime515's Avatar
Chime515
3rd Gear
Default Display turns dark a lot
The display in my 2015 C7 turns off (screen black) every time I drive. It might flick off as I go over a bump and turn on again with the next bump. Often it won’t turn on until I have been driving for 5-10 minutes. The battery is original (18,000 miles). Any chance the problem is the battery and not the display or the Hmi module? Thank you.
Old Aug 10, 2022 | 08:18 PM
kkupec02's Avatar
kkupec02
welcome. check/post in the C7 area
Old Aug 10, 2022 | 11:03 PM
Moved to C7 Tech.
Old Aug 11, 2022 | 02:01 AM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
At 7 plus years old it could be the battery. Replacement might be a good place to start before digging deeper to find the issue.
Old Aug 15, 2022 | 11:11 AM
Internets_Ninja's Avatar
Internets_Ninja
That year suffered from the cable issue I believe. If you search enough on the forum you will see the issue and the fix. It does involve removing the dash and infotainment unit to reach and replace with an updated cable. This could be the issue. Also, a failing HMI would cause the screen to go dark, but usually that issue causes the screen to go dark permanently with no radio or anything working.
Old Aug 15, 2022 | 11:24 AM
Travlee's Avatar
Travlee
does it come on for a second when you lower the screen? see my post 6 in this thread
https://www.corvetteforum.com/forums...reen-dark.html
Old Aug 15, 2022 | 09:39 PM
Maxpowers's Avatar
Maxpowers
This...and change the battery. It may fix it otherwise your on borrowed time otherwise.
Old Aug 21, 2022 | 09:28 AM
Chime515's Avatar
Chime515
3rd Gear
Lowering the screen does not seem to make a difference. After replacing the battery the display is on more than it’s off. But still not back to normal. When the screen is dark the radio still works fine, although I don’t think I’ve tried the phone/Bluetooth while screen is dark. My assumption is that it’s the display itself, unless Internets_Ninja is right about a cable.
To Display turns dark a lot
