Tips to change TCM
Old Aug 19, 2022 | 04:34 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
Default Tips to change TCM
Looks like my TCM bricked. Cannot find any tips/links/YT videos showing R&R process, Appreciate any tips to simplify process...
Old Aug 19, 2022 | 05:39 PM
laserdude2215's Avatar
laserdude2215
1) Disconnect electrical connector.
2) Remove failed module.
3) Install replacement module.
4) Connect electrical connector.
5) Program replacement module.
Old Aug 19, 2022 | 07:39 PM
Chalky's Avatar
Chalky
Does car have to be raised? More interested in processes used to remove!
Old Aug 19, 2022 | 09:11 PM
Bryan Berrong's Avatar
Bryan Berrong
It's in the right rear and just clips in. Very easy to remove/ replace. Jacking it up a little does help.
Old Aug 19, 2022 | 09:18 PM
Chalky's Avatar
Chalky
Thanks Bryan: Sounds like something I can handle!!
Old Aug 20, 2022 | 05:47 AM
TJay74's Avatar
TJay74
The new module will not come programmed, with that the car wont be driveable until it is programmed.
Old Aug 20, 2022 | 12:49 PM
Chalky's Avatar
Chalky
HP Tuner to the rescue..
Old Aug 20, 2022 | 09:21 PM
TJay74's Avatar
TJay74
Sorry to burst your joy, HP Tuners cant handle this. The new TCM comes bare with no OS on it and the VIN has not been flashed either. So unless the place you are buying the TCM from is programming the TCM that idea wont work. Also if this is a 2017+ TCM it will need to be unlocked by HPT again before you can tune it.
Old Aug 20, 2022 | 11:42 PM
Chalky's Avatar
Chalky
Did not know. Guess it adds another step to my repair. Good news is a friend is a Vet tech at local Chevy store.. Any idea/estimate on programming costs?
Thanks for update.
Old Aug 20, 2022 | 11:44 PM
Bryan Berrong
I bought mine programmed and unlocked from HPT
Old Aug 20, 2022 | 11:59 PM
Chalky's Avatar
Chalky
Might be an idea Bryan. Right now my car is immobile/in my garage. As I understand it, now, TCM has to be in car to be programmed, I don't know or can TCM be programmed on a carry in basis?
Maybe see if HPTuner can program my "new" TCM or a buy a preprogrammed TCM from HP Tuner. Turning out to be a PITA based on what I didn't know..
Old Aug 21, 2022 | 03:04 AM
TJay74's Avatar
TJay74
When you pull your TCM there will be a "Service Number" on the label of the TCM, make sure to take a picture of that label. Then you can see if HPT has that TCM in stock. If they do then yes you can order a unlocked and preprogrammed TCM from them. It comes with the OEM calibration on it, you will just have to license the new TCM (4 credits at $50 each) and then flash the new TCM with your TCM file that has your changes.
Old Aug 21, 2022 | 03:21 AM
Chalky's Avatar
Chalky
Thanks for reply. So I need to buy a TCM from HPT. I have a ticket in for more info on options if I go through HPT.. Price seems to be $299-$399. I assume that is for the credits and ECM w/programming.
My car is a `15 so not sure why I would have to cough up $200 /4 credits. I'll contact them Monday. I have a new one coming Tuesday but if I can find a way to obtain a working TCM Monday, I am all in.. Looks like HPT is 1st choice depending on turn-around..
Thanks for info. Will see how call goes Monday..
Old Aug 21, 2022 | 05:50 PM
Chalky's Avatar
Chalky
So, bought a new jack, located TCM, pushed red lock clip forward, wiring harness not separating from harness.. Does harness pull straight down from TCM? Just trying to be careful with harness and plug..
Update, got wiring harness released, cannot remove TCM from bracket. Video for c7 shows installer pushing up release on bracket release. I can push up on release but tcm will slide out.. Anyone see me missing anything?
I found one video of TCM R&R. Literally a b4 and after video.. Not much value,
Old Aug 21, 2022 | 08:16 PM
TJay74's Avatar
TJay74
If you have a 2015 you wont need the unlock service, will just need a new TCM programmed with the correct VIN and OS. To license the new TCM is 2 credits which is $100.
Old Aug 21, 2022 | 08:25 PM
Chalky's Avatar
Chalky
Good news, thanks.. Finally. LOL Got TCM out..
Old Aug 24, 2022 | 02:02 AM
Chalky's Avatar
Chalky
Also found out that 2015/2016 cannot be bench programmed. TCM has to be installed in car to program.. Got new TCM installed. Now trying to find a dealer to tow vehicle to to get programmed.
To Tips to change TCM
Old Aug 24, 2022 | 08:24 AM
GreenVette9's Avatar
GreenVette9
Ask around, when I needed mine done I found a guy that does gm programing mobile. He came out and hooked up his laptop and was done in 30 mins.
Old Aug 25, 2022 | 12:53 AM
TJay74's Avatar
TJay74
Hopefully the dealer wont rape you over the coals since you didnt buy the module from them and pay their labor for a install that only takes 5 minutes.
Old Aug 25, 2022 | 10:15 AM
Chalky's Avatar
Chalky
Thanks for tip. I did find one person in my market who has a mobile programming for GM. He seems to only work with dealer network but may make an exception for me.. Will know Friday. Found two people on FB who do same but require me to purchase $4K in scan software. LOL..
