Tire patch?
Old Aug 31, 2022 | 04:03 PM
Wujekcity's Avatar
Wujekcity
Default Tire patch?
Probably a dumb question....but I assume that I can plug a leak in my c7 GS rear tire like any other car? I have a slow leak and assume I ran over a nail or something.....is this safe??
Old Aug 31, 2022 | 07:50 PM
Maxpowers's Avatar
Maxpowers
As long as the leak isnt too close to the sidewall you can plug. Hopefully not a cracked rim..
Old Sep 1, 2022 | 02:48 AM
Wujekcity's Avatar
Wujekcity
I have the nickel pearl rims....hopefully its not cracked...if it is....its rhe rim i have 2 scratches on
Old Sep 1, 2022 | 09:23 PM
Wujekcity's Avatar
Wujekcity
it was just a piece of metal that I drove over somewhere!! 10 min plug! Im gonna need new tires after the winter up here in the Northeast anyways =) thanks Maxpowers
Old Feb 8, 2023 | 12:38 PM
KGoodwin's Avatar
KGoodwin
If you drive a Corvette, you don't plug.
Old Feb 8, 2023 | 12:49 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
You can use dyna plug to fix it, it will work.. just don't go to a track day with a plugged tire. A better way would be inside plug/patch but obviously you have to take tire off wheel for that
Old Feb 9, 2023 | 08:45 AM
CraigStu's Avatar
CraigStu
I was a Lexus dealer tech when the first model w/ run flats came out. OMG, no you can't plug a run flat. Owners didn't like buying a new $300 tire just because of a nail. A year later. OK, you can put a patch on the inside of the tire. Owners didn't like paying one hour labor for dismounting, patching, re-installing and balancing. Another year goes by. OK you can plug it w/ one of those plugs that expands inside the tire. Those plugs are a complete pain in the a-- to use. A few months later we were using these.
Amazon.com: Tooluxe 50002L -35 Piece Tire Repair Universal Heavy Duty Tire Repair Kit with Plugs, Fix A Flat Tire Repair Kit, Ideal for Tires on Cars, Trucks, Motorcycles, ATV Roadside Emergency, Tire Plug Kit : Automotive Amazon.com: Tooluxe 50002L -35 Piece Tire Repair Universal Heavy Duty Tire Repair Kit with Plugs, Fix A Flat Tire Repair Kit, Ideal for Tires on Cars, Trucks, Motorcycles, ATV Roadside Emergency, Tire Plug Kit : Automotive
To Tire patch?
