Rear ABS CABLE
Old Sep 15, 2022 | 07:17 PM
Russkier's Avatar
Russkier
Default Rear ABS CABLE
Can anyone tell me how to remove the rear ABS cable where it mounts to the body? (Drivers side) I'm installing Wilwood brakes and i need to remove this for clearance. The other side luckily just came off when i was trying to remove it. Thanks!
Old Sep 16, 2022 | 04:24 PM
ss2z06's Avatar
ss2z06
Do you have a pic of what you’re talking about?
Old Sep 21, 2022 | 12:26 AM
Bill Dearborn's Avatar
Bill Dearborn
Not quite sure which end of the ABS harness you are referring to. Is the ABS harness with the red arrow pointing to it the one you want to move?
Or Is there a problem fitting the ABS harness to the new brake hose that runs from the caliper to the brake hose mounting bracket on the cradle?
Bill
Old Sep 21, 2022 | 04:12 PM
Russkier's Avatar
Russkier
I finally figured it out, sorry for not answering this sooner. it was upstream at the connection. Thanks though!
To Rear ABS CABLE
