Cracked wheels question
Old Sep 21, 2022 | 05:19 PM
C7Dave2019's Avatar
C7Dave2019
Default Cracked wheels question
I've owned my new to me 2019 GS for about 6 weeks now and absolutely loving it, my first vette. My dealer agreed to swap the stock wheels with the chrome Z06 wheels & tires from another vette on his lot to make the deal. They have approximately 4500 miles of use currently. I am considering new Michelin all seasons (AS4's?) to be put on before next summer as we are planning some longer road trips and have heard the Z06 tires can be sqirrely in the rain. My question is more regarding the wheels. I have heard many stories of the cracking wheels. Should I consider replacing the wheels at the same time to avoid the inevitable (?) or am I worrying too much about a low probability (?) event ?
Old Sep 22, 2022 | 12:26 PM
JosephMingle's Avatar
JosephMingle
Long list of woe here: https://www.corvetteforum.com/forums...roll-call.html
I, like many, moved to Continental Extreme Contact non run-flat tires and haven't had an issue since having to replace both rear wheels. No pot holes, no curb impacts... just a "flat" tire that turned out to be a cracked wheel with the other cracked but not yet leaking.
BTW, the Conti's eliminated the "tramming" I experienced with my GS and are a significant improvement in wet weather conditions.
I have to admit, I like the sidewall profile of the Michelins much more, but hey, cracked wheels... no thanks.
I now have 40k miles, about 25k since switching. No rim issues.
Lastly, I carry a Milwaukee inflator, tire patch kit just in case... and of course a phone in case I can't effect a roadside fix.
And welcome to the GS - fantastic car as you now well know!
Old Sep 22, 2022 | 12:46 PM
vader86's Avatar
vader86
The PSS can get squirrely in rain, Weather Mode does help, but large puddles or torrential downpours, don't be going fast; the optional Cup tires you don't want to get into any rain, ever.
I cracked the RR wheel on my 19 GS within a month of ownership, it was a slow leak and you could drive on it so long as you monitored and added air about once a month or two.
So yes, the wheels will likely crack at some point.
Old Sep 22, 2022 | 03:17 PM
C7Dave2019's Avatar
C7Dave2019
Thanks so much for the input. Looks like it's about to get expensive. I love the look of the chrome Z06 wheels so probably look into the Replica brand comparables.
Old Sep 22, 2022 | 03:27 PM
CJ Willys's Avatar
CJ Willys
Worrying too much. I’ve owned 4 sets OEM Z06 wheels. None have cracked.
Old Sep 22, 2022 | 04:15 PM
C7Dave2019's Avatar
C7Dave2019
Great to hear. I'm just not aware how prevalent the issue really is.
Old Sep 22, 2022 | 07:28 PM
Maxpowers's Avatar
Maxpowers
Nobody does. If I were you I would react to the problem if you get it....rather than be proactive and buy aftermarket (unless you want a new look).
Old Sep 23, 2022 | 08:08 AM
Toddster993's Avatar
Toddster993
I cracked a wheel the first day i drove home from the dealer, also a slow leak was the clue as i never even hit a pot hole large enough to realize it. It was a slow leak so i had to fill up a few times to get home but not catastrophic. I ended up buying forged wheels instead just for peace of mind. They are pricey though.
Old Oct 1, 2022 | 12:47 AM
Avanti's Avatar
Avanti
Simple, sell the OEM... someone will likely want them (see the "Parts for sale/wanted" section here). Then, buy a set of quality, fully-forged aftermarket. Such should be considered part of the cost of a wide-body C7 if you intend to drive it. All the best.
To Cracked wheels question
