Knock Sensor Location??
Old Oct 13, 2022 | 07:44 PM
8five's Avatar
8five
Default Knock Sensor Location??
Trying to figure out the location of the knock sensor. I'm assuming this it? (PN 12623095)
Also, is it true theres two of them on either side of the engine? Thats what I was told anyway. :S
Trying to help a buddy find out where it is on his ZL1. I'm assuming the locations would be the same on both cars?
Old Oct 14, 2022 | 06:48 AM
mdformula350's Avatar
mdformula350
the part number definitely comes up as a knock sensor. https://www.gmpartswarehouse.com/oem...bC12OC1nYXM%3D
appears to mention in my searches sensors so you're probably right one for each side of engine. would assume they both look the same with the bolt through it. maybe on the front other side for the other?
but overall would guess same location overall for these engines.
Old Oct 14, 2022 | 07:29 AM
8five's Avatar
8five
Yeah I realized after I posted the photo that the sensor looks much different than the one I circled.
I can't find any photos of the engine at the right angle, but my guess would also be somewhere at the bottom front of the engine. Will check that next.
Old Oct 14, 2022 | 10:35 AM
laserdude2215's Avatar
laserdude2215
Look lower on the side of the block - one on the left, one on the right right.
To Knock Sensor Location??
