Header install thread
I remember reading a very comprehensive install here on a dry sump car.
Anybody save this thread or a link??
Thanks,
Bill
Another good thread - https://www.corvetteforum.com/forums...xperience.html
And another - https://www.corvetteforum.com/forums...s-to-help.html
I just installed ARH - no trouble at all... well, except I did have to expand the ARH pipes a bit - maybe because I have 40k miles.
The sound is fantastic - well that and the A&A noises - a concert of sound.
I guess some explanation would help.
I'm a little embarrassed to admit, I didn't research cerakote sufficiently... I was really looking for thermal management and while the cerakote that was applied is good to "1850?" degrees F, it does nothing to reduce under hood heat. And despite great care, the finish is so fragile that simply tapping a wrench against the finish tightening header stud nuts is sufficient to chip the finish.
So, it looks fantastic...
This picture shows contact damage when I installed the header installed (with cotton towels wrapped around them)...
And next, what happened when a tech, during dyno tuning, had to pull a spark plug boot with spark plug boot pliers...
And then what a couple wrench contact taps did tightening the header nuts...
Someday I'll pull them and get them ceramic coated. I have powder coated items more resilient than this stuff... glad I didn't have any of my wireless hole punches done in this stuff.
I'm a little embarrassed to admit, I didn't research cerakote sufficiently... I was really looking for thermal management and while the cerakote that was applied is good to "1850?" degrees F, it does nothing to reduce under hood heat. And despite great care, the finish is so fragile that simply tapping a wrench against the finish tightening header stud nuts is sufficient to chip the finish. So, it looks fantastic...
So it looks good for an ornament in my living room but totally worthless for thermal management. IOW, Don't buy it for the headers in the car. I don't care how it looks. I want it to reduce underhood temps if I get it.
Are you going to do it inside and out or just outside? I have had my TPIS ones on the C4 inside and out. Not sure about the ROI on a C7
Fred
