I just installed an MSD Atomic intake on my 2016 C7, I used a stock ported TB, any benefit of going to 95MM?
There is almost ALWAYS improvement in hp
even on stock cammed cars. And not just the "feel" at throttle tip in. I would go right to a NW or Katech 103mm. Stock is 87. I had a wildly cammed LS3 with a ported Katech 90mm TB. I also had a Nick Williams 102mm but I couldn't get it to be smooth on tip in. It was choppy and abrupt--even after alot of time spent tuning. I reinstalled the ported LS3 TB and sold the 102 NW. I was tuning it myself and was learning at the time (well still learning!) and I believe a more experienced tuner could've made it work great. Keeping the 102 would've DEFINITELY made more power than my ported 90mm. The ported stock 87mm just can't compete with a 103mm TB. Just make sure to port the opening of the MSD to match the 103mm diameter (if it isn't already)
I ported my own, I did see a dyno test by a tuner that added a 103 to a stock cammed car, there was no gain really 1hp. Probably gain throttle response more than anything
