3300 corvette battery charger question
Old Dec 9, 2022 | 06:14 PM
70vetteinpieces's Avatar
70vetteinpieces
Default 3300 corvette battery charger question
In the manual
If the US 3300 Corvette ( model 1051) does not switch to maintenance charge mode after three days, manually switch it to pulse maintenance mode
Can't find in the manual how to switch it manually. Unless I am blind and some hidden button somewhere on the charger...
Seems when I hooked it up first time all was fine. Then did some cleaning and set the alarm. Now the charger doesn't go to maintenance mode
Old Dec 9, 2022 | 09:11 PM
NortonCO's Avatar
NortonCO
There is no switch on the US 3300 Corvette Model 1051 charger. It's a rebranded (and slightly modified) CTEK 3300. Unfortunately, the modifications included removal of a MODE button the CTEK-branded version has. It looks like the Owner's Manual was not updated to reflect the change.
T
he most likely reason why the charger doesn't switch to Maintenance Mode within three days is a worn out battery that should be replaced.
Old Dec 11, 2022 | 07:28 PM
70vetteinpieces
T
Took it off for 3 days and reattached charger - went to green ( maintenance mode) in about 4 hours.
Sad they make a model with the Corvette name but make it a cheaper version removing some modes
To 3300 corvette battery charger question
