Coolant reservoir replacement
Old Dec 16, 2022 | 06:14 PM
M1ne's Avatar
M1ne
Navigator
Default Coolant reservoir replacement
Has anyone replaced this? Why and any pointers
2016 Z07 120,000 miles
seems like the purge valve is worn out, not sure if there is such a thing on the reservoir but a very small amount of fluid is leaking at the reservoir location with the reservoir at correct level. Started all of the sudden. No engine leaks, KaTech Stage 4 build at 107,000
thanks
Old Dec 16, 2022 | 06:56 PM
RonC7's Avatar
RonC7
The pressure cap on the coolant reservoir will relieve excess pressure.
Check the gasket on the pressure cap and replace the cap if needed. This is easy and cheap.
There were reports of coolant reservoirs with bad threads leading to coolant leaks, but they showed up before 100K miles.
If there are no connection or line leaks, then you may have to replace the reservoir.
Ron
Old Dec 18, 2022 | 09:41 AM
M1ne's Avatar
M1ne
Navigator
Default Coolant Reservoir Leak
Ron, thanks for the reply, great information. I did view the bottom of the reservoir with my Tslong borscope showing possibly a drip mark on the lower section but it’s not wet. I do have a replacement reservoir on the way and it has a new cap (EBay - new)
The cap will relieve excess pressure but where does it actually expell from? The cap itself? If so it would seem the area around the cap would be wet. I have not opened the reservoir since the KaTech build last year and this leak appeared all of the sudden.
Thanks very much!
Old Dec 18, 2022 | 09:58 AM
RonC7's Avatar
RonC7
Yeah, I would expect the cap to vent mainly vapor unless the car is really overheated. There is no hose or anything on the cap so pressure relief drips or stains should start at the filler neck.
i would still do the easy thing first and just change the cap - then see what happens.
Ron
To Coolant reservoir replacement
