C7 tire advice
Old Feb 2, 2023 | 07:36 PM
mark c7 stingray's Avatar
mark c7 stingray
Cruising
Default C7 tire advice
I have a C7 with Z 51 and mag ride control that is supercharged. Has Nitto 555G2 s on front and Nitto 305-30-20 555 Rll s drag radials on rear. works great on street but spins on drag strip. Am going to be doing some road racing this summer and was wondering if anyone has any experience with drag radials on a road course. This is for fun I will not be competing so I don't need to have world class tires but want to get after it. Have to have drag radials on the street for safety and if they will do well on road courseI would like to stick with them , thanks
Old Feb 7, 2023 | 02:26 PM
SouthernSon's Avatar
SouthernSon
Most that do road course HPDE's eventually gravitate toward Hoosier R7's. Even though you may not do W2W nor pursue the 'fastest time of the day', when you get passed by someone that has a comparable car (well, even one that is way above) you will desire all the performance you and the car can muster.
Old Feb 7, 2023 | 02:58 PM
squirrelchew's Avatar
squirrelchew
drag radials won't do well on a road course, the sidewalls are too soft and they generally don't handle the heat well. the nittos are barely a drag radial, however, as they are much more on the street tire side of things. consider using tires designed for the thing you want to use them for, otherwise you run into the all-season tire dilemma.
Old Feb 16, 2023 | 11:20 AM
mark c7 stingray
Cruising
Hoosier R 7s only come in 15"
Old Feb 16, 2023 | 11:05 PM
squirrelchew
not sure who told you this, but stop listening to them. they come in a ton of sizes from 13" to 20"
tirerack has a bunch available.
Old Feb 17, 2023 | 08:59 AM
96GS#007's Avatar
96GS#007
If you're new to road racing, stick to a 200TW street tire or an R-compound like the NT01, R888R, or Goodyear Supercar 3R. They'll give you a little warning at the limit and won't cover up driver bad habits. Hoosiers and slicks work....until they don't. You may want to poke around in the Autocross & Roadracing section of the forum regarding car prep. Just "showing up" is not advisable.
Old Feb 17, 2023 | 10:24 AM
SouthernSon
Although you may eventually end up with the Hoosiers I suggested above, I will agree with 96GS that a more 'progressive' tire with tread is a good tire to begin tracking. I believe it was Firestone Wide Ovals that I first went to track many years ago. I found the noise/sqeal (progressive) to be helpful in indicating when pushing the tire to the limit. Also, probably the best teaching of the squeal was learning how just the slightest loosening of the steering wheel, sometimes not even a noticeable movement of the wheel, would eliminate the stress on the tires. This is most important when graduating to a stickier, less progressive tire. However, I have never noticed the stickier R6's and R7's to be difficult to regain control when exceeding limits. If anything, a little countersteer/correction bring them back under control maybe quicker than a more progressive. But this all depends upon how far the other side of control one lets the vehicle get. Tires require familiarity as one progresses through track experience.
Old Feb 17, 2023 | 10:26 AM
mark c7 stingray
Cruising
thanks for the input I am leaning toward the NT-01s but still have some research to do . I also travel with this car so I need something I drive on the highway also.
Old Feb 17, 2023 | 10:27 AM
SouthernSon
I just saw this post. It is incorrect. I now have 19" and 20" R7's mounted on the Forgelines on the C7GS.
mark c7 stingray
Cruising
yeah tire dealer who only carried those sizes, thanks
Old Feb 17, 2023 | 10:28 AM
mark c7 stingray
Cruising
thanks
Old Feb 17, 2023 | 02:15 PM
SouthernSon
You are not the only one to get misled that way. Ask me how I know.
To C7 tire advice
