C7 Targa Top Squeaks
Old Feb 6, 2023 | 06:43 AM
gajin's Avatar
gajin
NCM Founding Member
NCM Lifetime Member
Default C7 Targa Top Squeaks
Best way to eliminate Targa Top squeaks on 2015 C7 Z51?
Old Feb 6, 2023 | 09:35 AM
AnotherNorskie's Avatar
AnotherNorskie
303 Seal conditioner: https://a.co/9gAEcL3
Old Feb 6, 2023 | 10:07 AM
Jeff V.'s Avatar
Jeff V.
The best way to fix it is to replace the strikers with the updated version.
https://www.corvetteactioncenter.com...ving-1276.html
The cheap way is to stuff some o-rings in there.
https://www.corvetteforum.com/forums...asy-2-fix.html
Old Feb 6, 2023 | 10:24 AM
NortonCO's Avatar
NortonCO
Old Feb 6, 2023 | 10:56 AM
Travlee's Avatar
Travlee
just ordered the pins for mine... pretty sad that shipping is $11 for 2 small parts
Old Feb 6, 2023 | 01:08 PM
Jeff V.'s Avatar
Jeff V.
Pins alone won't do it. You need the updated striker plates.
Old Feb 6, 2023 | 01:34 PM
Travlee's Avatar
Travlee
i will see what the pins themselves do, if it still does it i will order the strikers and the seal along the back of the targa. i noticed the other day mine has a small slit in it
Old Feb 6, 2023 | 02:38 PM
Jeff V.'s Avatar
Jeff V.
I had noises on my original 2014 roof. I did the o-ring fix and that helped. It was still occasionally noisy, but good enough that I could live with it.
I later bought an exposed carbon fiber roof that already had the new pins. I put that on in place of the old one. It was horrible. The new pins with the original striker design didn't work at all.
I bought the new strikers. It was perfect.
Old Feb 6, 2023 | 02:57 PM
Travlee's Avatar
Travlee
good to know, thank you sir
Old Feb 6, 2023 | 08:33 PM
Avanti's Avatar
Avanti
OMG, there are a gazillion relevant posts here that an "Advanced search" across the C7 Forum sections will dredge up. Regarding them, there are about an equal number of things people have done to address the issue... with varying success. For me it was tightening the rear latch just "one more turn" than I really wanted to initially. All the best.
Old Feb 10, 2023 | 10:13 PM
gajin's Avatar
gajin
NCM Founding Member
NCM Lifetime Member
I took your advice and preliminarily used the 303 which I have used on my Class A slide-outs weather gaskets, etc. for years. It did quiet down the squeaks but I'll keep a good ear before taking other advice for folks that chimed in.
Thanks!
Old Feb 11, 2023 | 12:36 AM
Travlee's Avatar
Travlee
Are new strikers needed or just latches?
Old Feb 11, 2023 | 11:11 AM
Jeff V.'s Avatar
Jeff V.
Pins and strikers. The latches don't need to be changed. Everything you need to know is in the first link in post #3.
Old Feb 11, 2023 | 12:42 PM
Travlee's Avatar
Travlee
Thank you sir. Dang they are proud of their plastic pieces
Old Feb 11, 2023 | 01:18 PM
Jeff V.'s Avatar
Jeff V.
The striker plates are cast aluminum. The pins are steel with some kind of low friction plastic sleeve.
Old Feb 12, 2023 | 09:35 AM
Travlee's Avatar
Travlee
ordered the strikers and rear weather strip this morning. will let yall know results when i get them put on
Old Feb 20, 2023 | 06:06 PM
Travlee's Avatar
Travlee
Is there a video or pics how to replace the strikers? Of course gm didn't make it easy just by looking at it
To C7 Targa Top Squeaks
Old Apr 25, 2023 | 12:36 PM
Travlee's Avatar
Travlee
Finally got around to having this done, new strikers and pins.....silence. finally after 3 years it's quite. Seems the new strikers pull the targa down more
Old Aug 2, 2024 | 08:05 AM
vortech347's Avatar
vortech347
Resurrecting this older thread. I have the new strikers to replace now but can't seem to find any links with instructions on how to change them. They look pretty straightforward but it's nice to have a video or document with the proper procedures.
I already have the updated pins as my car is a 2016 but it has the old style strikers and creaks like crazy when hot outside.
Old Aug 2, 2024 | 08:18 AM
Travlee's Avatar
Travlee
i found it one day, will see if i can find it again. off the top of my head, mirror removal, sun visors, that little strip of headliner. @96GS#007 has been really helpful at posting info from alldata
i got lazy and took mine to corvette world to have them do it
