02 sensor issues
Old Feb 14, 2023 | 07:03 PM
monroepaul's Avatar
monroepaul
Default 02 sensor issues
I just installed long tube headers and didn’t label the 02 sensors before disconnecting. Is it possible to reverse them and if so will that cause issues?
Old Feb 14, 2023 | 08:10 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
As far as the rear O2’s the wiring crosses over so the left rear O2 connects to the harness on the right side and same with the right…the connectors are different shapes so at the front of the engine you can’t cross them !!
