“Stabilitrak” error
Feb 17, 2023 | 07:49 AM
“Stabilitrak” error
I just finished installing new control arm bushings, adjustable granatelli links in the rear and AMTs camber kit. I took her out for a shake down drive and a minute in the STABILITRAK light came on. I know it needs an alignment after all i have done, would this error be related to my suspension components being too far out of alignment?
Feb 17, 2023 | 09:32 AM
Might be although its likely a wheel speed sensor may be disconnected or a wire broken when you took out the a arms
Feb 17, 2023 | 09:38 AM
Quote:
Originally Posted by
ErnieN85
Thanks, I will double check my wheel speed sensors
Feb 17, 2023 | 09:44 AM
Toddster993
You might want to check that the wheeels& tires are on the correct hub
Feb 17, 2023 | 09:48 AM
not sure I follow what you are saying
Feb 17, 2023 | 09:55 AM
I once got the front & Back mixed up bad things happen then
Feb 17, 2023 | 09:59 AM
ErnieN85
Meaning you mounted the front tires on the rear of the car and rears on the front?
I will double check that, they are all 18s now so its possible
Feb 17, 2023 | 11:11 AM
Yes, and if the sizes are the same it won’t work there has to be the correct or close circumference difference front to back
