Short shift
Old May 3, 2023 | 07:18 PM
Bacon55's Avatar
Bacon55
7th Gear
Default Short shift
I have a C7 ZO6 CORVETTE, I got my short shift from MGW, and would like to get it installed. Do you know anybody in Orange, CA, to do the job?
Old May 3, 2023 | 07:42 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
There is a regional section for So. Cal. Maybe post here.
http://www.corvetteforum.com/forums/...california-45/
Old May 4, 2023 | 02:06 PM
miami08VETTE's Avatar
miami08VETTE
Depending on your DIY skills and tools available, it's not that hard to do. Just time and patience! Good Luck...
Old May 4, 2023 | 02:26 PM
Flattman's Avatar
Flattman
Too bad I'm in Phoenix, I'd love to help as I installed mine. It's pretty straight forward and I bought mine used without the alignment tool. Lot's of videos on YouTube about that and the removal of console pieces.
Old May 4, 2023 | 03:24 PM
Bacon55's Avatar
Bacon55
7th Gear
Thanks for the answers, let me ask you this, is it worth to put the MGW shifter, did you see any benefits?
Old May 4, 2023 | 04:54 PM
Flattman's Avatar
Flattman
I prefer it over the stock as it's just more precise and crisp transitioning between the gates. I feel the MGW helps with the speed (reduced movement) of shifts and a less ambiguous feel versus the stock unit. I also feel the feedback of it helps with proper gate selection. The longer throw of the stock unit in my opinion makes the narrow gate selection more difficult with the M7. My car is not a daily driver, I'm sure if it were I'd be even better. The other great thing about the MGW is if you don't like it, you can always sell it for pretty much what you paid, minus a rubber gasket that gets trimmed during the process.
Old May 5, 2023 | 01:39 PM
vortech347's Avatar
vortech347
Way better than stock and not very hard to install.
Old May 5, 2023 | 04:08 PM
miami08VETTE
My opinion is that it's an absolutely noticeable improvement over stock. Shortens the shifts and introduces a precision that the OE will never have. IMHO...
Old May 5, 2023 | 04:24 PM
Bacon55's Avatar
Bacon55
7th Gear
Thanks guy for all your replies
Old May 8, 2023 | 01:02 AM
NortonCO's Avatar
NortonCO
Agree with everyone who said noticeable benefits (i.e., shorter and more precise than stock) and relatively easy install (i.e., provided instructions are good and there are a number of videos available online).
Old May 8, 2023 | 06:40 AM
mdformula350's Avatar
mdformula350
greatly improved for me as well.
first time doing one and took my time a few hours.
watched a few youtube videos to ensure I had the right idea.
be gentle with the trim
use proper plastic trim tools
definitely ensure you have the tools before you start, its a large torque bolt for the shifter cable
also ensure its adjusted properly and torqued to spec before buttoning back up
best of luck. well worth mod for sure.
Old May 8, 2023 | 04:29 PM
fxdwg's Avatar
fxdwg
Default Trim removal tools
Who’s got a good link for decent trim removal tools?
Old May 8, 2023 | 10:12 PM
JonMN's Avatar
JonMN
I did my own too. As mentioned, there are several videos around. It's pretty easy. For me, by far the most time was spend digging out the small allan wrench I dropped during installation. If you do this, consider stuffing some rags or something around the area until you are ready to close up. Dropping something in the tunnel was not fun at all.
As others have mentioned, the shifter is great. Really precise.
Old May 9, 2023 | 10:24 AM
Flattman's Avatar
Flattman
I have this trim tool set from Harbor Freight and it's worked great. Have had the console apart, splash guards, front nose removed and rear facia off with these.
Old May 14, 2023 | 04:07 PM
MBrianB's Avatar
MBrianB
Question on MSW Flat Stick Short Throw and Short throw. Which one for what purpose? Why one style over the other.
Old May 14, 2023 | 04:22 PM
vortech347's Avatar
vortech347
IMO personal preference on the look. At least from what I read thatxs the main difference.
Old May 14, 2023 | 05:30 PM
JonMN's Avatar
JonMN
^^^ That's what I heard too. The geometry is supposed to be the same. The standard MGW lets you reuse the stock ****. I went flat stick mainly because I actually liked the retro look of the spherical ****. It also opens you to more aftermarket *****, if you want to try a weighted ****. (I really like a weighted ****)
Old May 14, 2023 | 05:36 PM
vortech347's Avatar
vortech347
You can still use aftermarket ***** with the regular shifter. You just have to buy the threaded shifter rod instead of the one designed for the stock ****.
To Short shift
