DTC code
Old May 6, 2023 | 08:46 AM
9sec's Avatar
9sec
Default DTC code
seems I have picked up a dtc U0100-00. looking the code up it seems theres a communication error with ecu and hard starts are a symptom which I seem to have now.
doesn't really go into detail on where to start looking or what causes the communication failure
ideas?
Old May 6, 2023 | 09:05 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Found this in my helms 11:56. THere are 4 pages on this DTC
How old is your battery?
Elmer
Old May 6, 2023 | 09:43 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
First have your battery checked and also it’s connections…for any single module “no comm” you would check all powers and grounds to the ECM.
Old May 6, 2023 | 09:52 AM
9sec's Avatar
9sec
battery is a 720 cca agm and less than 2 months old. cables are fresh and clean. alternator is also new and 2 months old
I would think if everything was connected the code could be cleared and move on but as soon as the code is cleared it comes back and im encountering a 6-8 second delayed start now
Old May 6, 2023 | 09:57 AM
C5 Diag's Avatar
C5 Diag
What model year is the car ???
Old May 6, 2023 | 10:21 AM
9sec's Avatar
9sec
2017 z06 w/ z07 pkg 18k miles
Old May 6, 2023 | 11:10 AM
C5 Diag's Avatar
C5 Diag
OK, thanks !!…your profile shows a 2010 so you may want to edit that with model year, mods, tune etc…like I said if you can’t comment with the ECM I would check these 2 fuses with a 12 volt test light…the ECM fuse (10 amp) is fed from the battery so it should be “hot at all times”…the ECM (30 amp) is fed from the engine ignition control relay so that fuse should receive power when the engine is cranked…I hate that Alldata does not show a fuse number…both should be in the underhood fuse lock…a quick check to see if your ECM is “alive” is to see if there is a 5 volt reference voltage on any one of the sensors…this 5 volts comes from a generator within the ECM…you can unplug the MAF/IAT sensor and see with a DVOM if you have 5 volts on the WHITE/RED wire…hold the bottom of the start button down for 5 seconds…don’t remember if you can power it up in ACC.
To DTC code
