Just remember what ever oil filter you use that it has a by-pass rating of 22 psi like that of the AC Delco PF64
you can also check out GM Service Bulletin # 17-NA-157 on the spin-on oil filter.
Hope this helps
makes no difference just like oil
pick whichever has the neatest looking box and the best marketing scams
Really , so you think so huh ........
I do all my own work but it's just not worth my time and effort to do an oil change and have to dispose of the oil and filter
, I take all my cars to a place that works on all high-end cars and that has been doing all my oil changes for years,
When I picked up the Vette last week, I instantly saw that the oil pressure seamed really high. , I figured it was new oil and it was not warmed up . fast forward to yesterday, its 90 degrees outside , Oil temp is 206 and pressure was still looking too high to me, so I jumped down hard on it and the pressure shot up to over 65 pounds, I drove directly to the shop, who then put it right up in the air where they discovered a knock off filter and not an AC Delco PF64 . After the manager chewed out the guy who worked on it , they put the correct filter on and my pressure is back to normal. Moral of the story ... there are a lot of filters that fit an LT motor .......but only a PF64 should be used.
Hope this helps
Plenty of comparison videos on filters. After reviewing a few, seems the AC Delco filter is right up there with the better examples. For my use (about 4K per year), it is a bargain. Offsets the overkill with the Supercar oil that I don’t really need. Cheap insurance.
R Moral of the story ... there are a lot of filters that fit an LT motor .......but only a PF64 should be used.
Dave
correct, the bypass rating matters, that is an objective physical part just like the diameter to fit up
I didn't say the bypass doesn't matter, I said the actual filter brand itself doesn't matter, because it doesn't
When I said oil doesn't matter do you think I meant go ahead and use Rotella 20w-50 diesel engine oil? Or 0w-20?
no, I meant Pennzoil synthetic 5w-30 or Mobil 1 synthetic 5w-30 or Amsoil or whatever people are hyped up about makes no difference other than personal opinion and how neat the jug looks
My point was not about the bypass , my point was about the knock off brand that was installed. There is a huge difference in filtration materials , check valve tolerance, and overall materials used
If you don't think there is a difference in brands I think you are sadly mistaken
I do agree with you on the brand of oil statements , as long as the oil you buy matches the OEM specs .... it all the same
0 is a temperature. as in 0 degrees. W means winter. As,,,, 0degreeswinter-30 0 weight is impossible. Even water isn't 0 weight. Weight and viscosity are two different things.
Oils viscosity doesn't get thinner as it gets colder,,, impossible.
facepalm
no it doesn't mean 0 degrees, and no it doesn't mean it's "zero" weight. No clue where you are getting any of this.
They are arbitrary numbers that provide a "scale" for what the actual viscosity is. Viscosity isn't represented by a unitless figure in multiples of 10.
0W-30 gives a numerical comparison of how that oil will flow when cold compared to 10w-30 or 20-50, or whatever
so it's "cold" viscosity is much lower than 10w-40 but it's hot viscosity is no worse than 10w-40, hence good cold operation characteristics without trading off hot operation
quite certain nobody is implying that 0W-40 is a superfluid when cold with zero viscosity because thus far the only thing known to man that can become a super fluid with zero viscosity is liquid helium chilled to absolute zero
It stands for 0 degrees. The oil spec is down to 0 degrees. Meaning the oil will maintain a certain viscosity down to 0 degrees instead of 10 degrees as in 10W-30.
0W-30 oil and 10W-30, both start with 30 weight oil, with additives the 0w-30 can maintain a certain viscosity down to 0 degrees instead of 10 degrees.
Do some research.
This will help. Look at the straight 30 weight compared to 0W-30, the viscosities. At the warmer temp's the viscosity is about the same, at the colder viscosities there is a big difference.
