AC Issues need guidance
Old May 19, 2023 | 02:44 PM
PMP-IN's Avatar
PMP-IN
Cruising
Default AC Issues need guidance
I have a 2017 Z51 2 LT and have started having AC issues. When I get on the engine the AC cuts off, no air and the blower stops. It can take almost up to 30 mins and it will come back. Air is cold. Any ideas on what this could be?
Old May 19, 2023 | 02:45 PM
squirrelchew's Avatar
squirrelchew
can you elaborate on your procedure here, specifically "getting on the engine" ?
Old May 19, 2023 | 02:52 PM
PMP-IN's Avatar
PMP-IN
Cruising
I mean I step on the gas and accelerate quickly and then let back off to normal..........nothing extreme.
Old May 19, 2023 | 06:48 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
So what you’re saying is the AC clutch disengages and the blower motor stops when you “give it the beans” and then both are inop for 30 minutes ???…this is what you need for your 2017 AC to work…you would really need to get a scan tool on the car to see what’s going on.
Old May 19, 2023 | 10:25 PM
squirrelchew
sounds like a loose connection somewhere.
To AC Issues need guidance
