Driver window stopped working
Old May 20, 2023 | 10:46 PM
Prodago's Avatar
Prodago
Default Driver window stopped working
After reconnecting the negative battery leads, my driver side window stopped working. I checked the no. 1, 30a fuse in the rear fuse box and that’s not the problem. I have been working on the a/c compressor which is why the negative was disconnect but can’t think they are related. Opinions??
Old May 21, 2023 | 12:12 AM
RonC7's Avatar
RonC7
Disconnect the negative battery cable again for 30 min and try again...
Ron
Old May 21, 2023 | 09:40 AM
ICONIC7's Avatar
ICONIC7
2025 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
Ron
And make sure it's tight!
Old May 21, 2023 | 05:10 PM
Prodago's Avatar
Prodago
Other than the window switch and the 30 amp fuse, are there any other parts in the driver side control circuit for the window? Is there a window motor fuse that I’m overlooking? I don’t know how to check the switch once it’s removed from the door panel, but the 30 amp fuse is in working order.
Old May 22, 2023 | 03:12 AM
pauldreazy's Avatar
pauldreazy
I just fixed this problem too a month ago. I ended up replacing the power window motor, dealership wanted me to pay $800 just for the part and said no. Luckily I found someone else and able to buy the parts and install it for $500. Hope this helps
Old Aug 17, 2024 | 03:13 PM
Young Bill's Avatar
Young Bill
Did your window go down when you opened the door? Mines does and this is making me think the motor is fine?
To Driver window stopped working
