AFM delete question
Old Aug 9, 2023 | 03:36 PM
Aerovette's Avatar
Aerovette
Originally Posted by aklim
I explored that end but I didn't want a lopey cam so it was stock profile if you want to do it.
I had lifters fail twice and the last time my truck was in the shop from early February until June and I got tired of waiting. The parts needed were in China and checking delivery a few times a week, I was constantly finding "Not available" at any dealerships or anywhere. ONE part was on ebay for about 4 times what it should cost. They wanted $1100.00. I called the shop and convinced them to do a delete. I got the truck back in a week and now own a tuner as well. Best move I ever made. It's a stock cam, but it's a truck so I don't care. It has Corvette lifters though .
Old Aug 9, 2023 | 04:10 PM
aklim's Avatar
aklim
Crazy question. Is is possible to switch in higher quality lifters to replace the stuff GM gave us or so the design itself FUBAR?
Old Aug 9, 2023 | 04:21 PM
Aerovette's Avatar
Aerovette
My understanding is this. There are weak/faulty GM lifters and then there are worse lifters available.
The shop that worked on mine gave me some advice between repairs.
Do NOT rely on your oil monitoring for oil changes. 5000 miles PERIOD.
Watch the oil level CONSTANTLY. Be OCD about it because according to them, less than half a quart low is a HUGE deal.
In my case, the lifter rotated in the PLASTIC keeper and the roller was perpendicular to the cam lobe. The first time it failed was caused by the VLOM being "sluggish" from extended use of oil ( I trusted the algorithms). It failed to pressurize / depressurize the lifter at #7 properly and resulted in failure.
Old Aug 9, 2023 | 06:30 PM
aklim's Avatar
aklim
Attached is my report. Apparently 4500 was under utilized and I would be fine to 6000. Could the oil be that much better? I doubt it. Have you had your oil tested like I had?
I decided to test to know the status of the oil instead of blindly assuming GM's algorithm was the best there was. Too bad it wasn't like MB with an oil quality sensor.
Lifters look like they are here to stay or remove the entire AFM system and have to retune for a rougher idle cam. Too bad we can't have better quality AFM lifters.
File Type: pdf
Old Aug 9, 2023 | 10:46 PM
aklim's Avatar
aklim
What oil do you use? I'd be curious to see what happens if you test it at 4500 miles. I will have to wait for the oil change after the next to get 5W30 oil in and tested. Right now it is still with 0W40 Supercar since I had to buy more than I needed to do the previous one that I had tested.
Old Aug 9, 2023 | 11:58 PM
Aerovette's Avatar
Aerovette
0W20 Mobile 1
Why do you associate the full delete, with an aggressive cam? That is not a given. The cylinders that drop out ar ethe only ones with an odd profile. The AFM delete cam matches those lobes with the non-AFM lobes.
Old Aug 10, 2023 | 09:46 AM
aklim's Avatar
aklim
0W20 Mobile 1
Is that a recommendation for oil? I think it is 5W-30 or 0W-40. Maybe that is the issue? Again, without a test, we don't know for sure.
The places I asked for a quote said so. It was either stockish or aggressive. I prefer smooth running. Supposed to be that the aggressive cams might not pass smog.
Old Aug 10, 2023 | 01:25 PM
Aerovette's Avatar
Aerovette
I'm not sure who you consulted, but the EXACT match cam can go in that engine. Only the AFM lobes are different.
I don't want to miscommunicate. I am referring to a truck. Even though it is the same system etc. I can't speak to the oil recommendation for a Corvette vs a truck. I guess this disclaimer could certainly apply to a cam as well, but the fact that 4 cylinders already have a specific cam profile, logic dictates matching those will get you a stock cam with a stock idle.
The 2015 GMC Sierra 1500 requires 6.0 q of 5W-30 for the 4.3 L engine and 8.0 q of 0W-20 for the 5.3 L and 6.2 L engines and 8.5 q of 0W-20 for the Sierra Denali.
Old Aug 10, 2023 | 01:29 PM
Aerovette's Avatar
Aerovette
This may be of interest...
https://www.corvette-web-central.com...l-upgrade.html
Old Aug 10, 2023 | 01:34 PM
aklim's Avatar
aklim
Good to know. The dyno shop near me told me that the cam they will install is going to have some lope and won't pass emissions. I might have to ask what vendor you are going with. If you can remember. It might be worth it.
Old Aug 10, 2023 | 01:39 PM
aklim's Avatar
aklim
After this oil change I will be trying out 5W-30 so maybe next year we will see how much better it is when I get the lab results. So far, we know you can get 30% more life than what the OLM says according to lab testing. Looking forward to seeing where we land with 5W-30.
Old Aug 10, 2023 | 01:42 PM
Aerovette's Avatar
Aerovette
I did not choose my parts. The shop did and I don't know who they used.
This is where I would start.
https://sdparts.com/search.html?q=Co...AFM+delete+cam
Old Sep 11, 2023 | 12:07 AM
  #33
moreorless's Avatar
moreorless
4th Gear
I did the splitter and Range device as you suggested and I am extremely pleased with it. Thank you!
Old Sep 19, 2023 | 01:37 PM
  #34
Tate75's Avatar
Tate75
3rd Gear
I used EFILive tuning software and set mine to only allow AFM in 8th gear.
